| Oil weeping? https://slantsix.org/forum/viewtopic.php?t=53492 |
Page 2 of 2 |
| Author: | Rick Covalt [ Sat Oct 05, 2013 5:45 am ] |
Yes, What Charlie said, and then it runs the whole way along the head/block seam! Ask me how I know? Rick |
| Author: | CRANKSNAPPER [ Sun May 12, 2019 4:45 pm ] |
| Post subject: | Re: Oil weeping? |
PERMATEX COPPER SPRAY GASKET: OF COURSE, CLEAN SURFACES HANG HEAD GASKET FROM A WIRE OUTSIDE. SPRAY-COAT GASKET ON BOTH SIDES -- LET DRY 1/2 HOUR BEFORE NEXT APPLICATION. MINE IS 'MUDDY' WHEN I APPLY 50' Lbs - THEN 60..... LAST HEAD APP WAS IN '00, NOW '19......WOW !! -P- 425806520NINE |
| Author: | CRANKSNAPPER [ Sun May 12, 2019 4:47 pm ] |
I HAVE AN ALUMINUM SLANT SIX (1961) THESTOCKSGUY@HOTMAIL.COM |
| Author: | Doctor Dodge [ Mon May 13, 2019 5:48 pm ] |
Quote: I HAVE AN ALUMINUM SLANT SIX (1961)
Aluminum block Sl6 engines are challenging to seal...All the surfaces have to be completely flat and clean... It sounds like the block deck and head surfaces need re-machining so you can get the proper clamping forces on the head gasket. DD |
| Page 2 of 2 | All times are UTC-07:00 |
