| Setting up SPST Relay... https://slantsix.org/forum/viewtopic.php?t=53528 |
Page 2 of 2 |
| Author: | FrankRaso [ Wed Oct 09, 2013 7:27 am ] |
While I was out scrounging parts for my HEI upgrade, I grabbed the wiring harness out of a GM V8 HEI distributor. There is a capacitor wired to to the B terminal of the 4-pin module. I couldn't find its rating but (never having used this feature before) my Klein CL2000 clamp meter shows a capacitance of about 0.431 µF of the salvaged condenser. This measurement seems to be a bit different every time I check it. I read Joshua's recommendation as adding a 1000 µF capacitor in the feed line to the #30 terminal of the relay although it should be electrically the same as connecting to the #87. |
| Author: | Joshie225 [ Wed Oct 16, 2013 7:59 am ] |
1000uf is probably gross overkill, but it won't hurt anything. I can't see photos here at work. The most important factor here is that you chose something that you can mount securely. I'd use a nylon or rubber covered cable clamp screwed to the module mounting bracket if you have room. |
| Author: | kxracer728 [ Thu Oct 17, 2013 7:56 am ] |
I noticed on the axial leads capacitor that one end is a shiny metal and the other is black...Does it matter which end goes to ground? |
| Author: | mattelderca [ Thu Oct 17, 2013 8:25 am ] |
Shiny metal can part is usually the negative side of the cap. This should also be indicated by the - sign with an arrow pointing toward said shiny end. This end must go to ground. |
| Author: | kxracer728 [ Thu Oct 17, 2013 10:07 am ] |
Thanks for your response...i can see the - arrow pointing to the shiny metal end of the cap |
| Author: | Sam Powell [ Fri Oct 25, 2013 4:13 am ] |
I've been through this, and yes the alternator and other things under the hood will disrupt the HEI signal.I think the filtering concern is not as important with a carbureted engine. With EFI the fueling is based in large part by the RPM read, which outside interference effecting the HEI will sabotage. That being said, I have a separate fuse block on the fender for all switched voltage devices turned on by a toggle on the dash. There is a minute amount of theft protection in this switch as the car will not start and run without the switch on. The ECU, HEI and fan relays come off that block. The fan power comes from another source. I put ferrite chokes, and capacitors on the power leads. I also put ferrite chokes on the starter motor lead, and on the alternator feed. These are cheap devices found at Radio Shack for about $3 each. If you look at the power cord to your computer, or printer you will see one clamped around the cord. However I would reserve this addition until it seems needed. When I gounded my HEI module to the block it picked up noise from the starter, through ground when cranking. That might not be a problem with your carbureted car. The noise on the EFI application made the ECU think the engine was cranking at 6K, and flooded it. If it fails to start, check the grounding point. Just some more thoughts. Let us know how it goes. Oh yeah, I forgot to say, the switched fuse block is powered by a single large relay. The toggle turns it on. The toggle gets its power from B+ unswitched power under the dash. Sam |
| Page 2 of 2 | All times are UTC-07:00 |
