| Reverse manual valve body? https://slantsix.org/forum/viewtopic.php?t=5372 |
Page 2 of 2 |
| Author: | Charrlie_S [ Tue May 06, 2003 9:58 pm ] |
I don't know if they are still available, but I used to have a "Fairbanks" manual valve body with a "low gear safety feature". This applied the low band in 1st gear. Fairbanks is no longer in business, but there were other companies that had them available. |
| Author: | Dart270 [ Wed May 07, 2003 5:32 am ] |
Thanks for the additional info, Charlie and Dennis. Looks like the Cheetah is out, and I will look around for a MVB with low band apply. Chirp! Lou |
| Author: | Rob Simmons [ Wed May 07, 2003 9:45 am ] |
| Post subject: | Transpak, etc. |
My Jeg's catalog lists the B&M Transpak for the A-904 with 6 cyl 1966-77 as part # 130-10228 for $51.99. It says it's the shift improver kit with additional driver manual control. The tech guy couldn't really answer if it is reverse or forward pattern and/or if it applies the band for 2-1 downshift. It's about $84 cheaper than the Cheetah reverse valve body. They aren't all that scary inside. I can probably do this. Summit's catalog has the Transpak for .04c cheaper, but the tech help wasn't any better. Sorry that isn't much help. Maybe a call to B&M, etc is needed. Rob |
| Author: | slantzilla [ Wed May 07, 2003 8:00 pm ] |
What you will have is simply a good shift kit. You will still have to use the K-D linkage, it will be forward pattern, and it will still shift itself in drive. The main reason I went full manual was to get rid of the KD linkage, and the fact that I'm nuts. |
| Author: | Rob Simmons [ Thu May 08, 2003 3:18 am ] |
| Post subject: | Kickdown Linkage |
That's what I need since I don't have a kickdown. I thought if it was manual it deleted the need for the kickdown. So it would appear that I need the valve body itself rather than just a kit to modify mine(?). Thanks again. Rob |
| Author: | Dart270 [ Thu May 08, 2003 4:21 am ] |
Hmmm, my bros '68 Dart 318 had a manual kit in it from about 15-20 years ago (I think BM), and it had no kickdown and you had to shift it manually. It had really hard upshifts, but the 2-3 downshift was slippery. Lou |
| Author: | cycledog [ Sun May 11, 2003 5:10 pm ] |
try MP #p4007291, Earnhardt Dodge has the cheapest price on this part number that I have found. |
| Page 2 of 2 | All times are UTC-07:00 |
