It is currently Mon May 18, 2026 12:03 am
PostPosted: Fri Nov 08, 2013 8:57 pm
The solenoids are about a 2 amp draw with 5 amp fuse(if memory serves).
So it wouldn't take long to drain the battery.
PostPosted: Fri Nov 08, 2013 9:57 pm
The streetrod industry used to have barking brakes that attached to the yoke on the axle. Check with speedway and other outlets.
PostPosted: Sat Nov 09, 2013 10:57 pm
It's not a good idea because the tiniest of leaks will render the hydraulic lock useless in a short time.
Exactly. And my bet is that any piston sliding in a cylinder always has a small amount of leakage past the "rings" (or in this case seals)... they didn't design it to withstand a pressure application of more than a minute or two. If it can hold for longer, great, but the mfr doesn't expect it to. And you would be thinking of at least hours, maybe days? I kinda doubt any brake system would hold with no bleed off, though I've not tried it.
Just to give a point of reference, the classic test for leaking seals in a brake system is hold your foot on the pedal for a minute, see if it stays rock solid or slowly sinks toward the floor. That test doesn't mention hours or days, either. ;)
- Erik
PostPosted: Sun Nov 10, 2013 12:47 pm
One of the reasons I went with a Ford 8.8 from an Explorer was to gain disc brakes in the rear with emergancy/ parking brakes. Right now I have them rigged up to the stock handle under the dash. But when I am done modding the trans tunnel for the T-5 I want to build a counsel with a E-brake handle into it, from a jeep cherokee I scrapped out a few years ago.
