| will line lock work as e-brake? https://slantsix.org/forum/viewtopic.php?t=53796 |
Page 2 of 2 |
| Author: | emsvitil [ Fri Nov 08, 2013 8:57 pm ] |
The solenoids are about a 2 amp draw with 5 amp fuse(if memory serves). So it wouldn't take long to drain the battery. |
| Author: | kesteb [ Fri Nov 08, 2013 9:57 pm ] |
The streetrod industry used to have barking brakes that attached to the yoke on the axle. Check with speedway and other outlets. |
| Author: | mpgFanatic [ Sat Nov 09, 2013 10:57 pm ] |
| Post subject: | hydraulic not equal long term sustain |
Quote: It's not a good idea because the tiniest of leaks will render the hydraulic lock useless in a short time.
Exactly. And my bet is that any piston sliding in a cylinder always has a small amount of leakage past the "rings" (or in this case seals)... they didn't design it to withstand a pressure application of more than a minute or two. If it can hold for longer, great, but the mfr doesn't expect it to. And you would be thinking of at least hours, maybe days? I kinda doubt any brake system would hold with no bleed off, though I've not tried it.Just to give a point of reference, the classic test for leaking seals in a brake system is hold your foot on the pedal for a minute, see if it stays rock solid or slowly sinks toward the floor. That test doesn't mention hours or days, either. - Erik |
| Author: | Mike_64_Valiant [ Sun Nov 10, 2013 12:47 pm ] |
One of the reasons I went with a Ford 8.8 from an Explorer was to gain disc brakes in the rear with emergancy/ parking brakes. Right now I have them rigged up to the stock handle under the dash. But when I am done modding the trans tunnel for the T-5 I want to build a counsel with a E-brake handle into it, from a jeep cherokee I scrapped out a few years ago. |
| Page 2 of 2 | All times are UTC-07:00 |
