| Back again! https://slantsix.org/forum/viewtopic.php?t=54184 |
Page 2 of 2 |
| Author: | Aggressive Ted [ Mon Jan 06, 2014 7:32 pm ] |
Quote: I don't think the old thermal choke was opening all the way.
You have to adjust the cam inside them from time to time to be sure they open all the way. I set mine for about mile from the house. Then it is fully open and idling at 600 rpm in gear. I don't think many folks do this maintenance and assume it's junk and throw them away. A little PB Blaster and a slight twist from my 18" Snap On flat blade, and your done and running in about 3 minutes.
| Author: | crater [ Tue Jan 07, 2014 1:20 pm ] |
Quote: Quote: I don't think the old thermal choke was opening all the way.
You have to adjust the cam inside them from time to time to be sure they open all the way. I set mine for about mile from the house. Then it is fully open and idling at 600 rpm in gear. I don't think many folks do this maintenance and assume it's junk and throw them away. A little PB Blaster and a slight twist from my 18" Snap On flat blade, and your done and running in about 3 minutes. |
| Page 2 of 2 | All times are UTC-07:00 |
