| I want to beat v8's !!! https://slantsix.org/forum/viewtopic.php?t=54404 |
Page 2 of 3 |
| Author: | alamb [ Tue Jan 28, 2014 9:35 am ] |
Thank you everybody I am going to try and add some of the suspension upgrades to my car that were mentioned. I will try and get some pictures up of the before and after too. thanks again |
| Author: | slantfin [ Wed Jan 29, 2014 6:08 pm ] |
If you have a single-reservoir master cylinder, changing to a split master cylinder is a low-cost improvement. With an old car, you want to be sure of your brake hoses and brake lines, too. Safety first. |
| Author: | alamb [ Sat Feb 01, 2014 11:52 am ] |
Will changing out torsion bars for thicker ones change the ride height of the car? or will it just make the suspension stiffer? |
| Author: | Aggressive Ted [ Sat Feb 01, 2014 12:12 pm ] |
Just make it stiffer. You can set them at any height, but I would go with the FSM for your car to get the tires to wear properly. Don't go with the numbers from a computer alignment rack.......take your FSM with you. |
| Author: | alamb [ Sat Feb 01, 2014 1:15 pm ] |
I might sound really dumb but what is FSM? Factory setting ..... or something like that |
| Author: | slantzilla [ Sat Feb 01, 2014 1:31 pm ] |
Factory Service Manual |
| Author: | alamb [ Sat Feb 01, 2014 2:11 pm ] |
Thanks So you think that i could just use some torsion bars from a mopar that had a 340 V8 in it? And do you by any chance know of any cars that came with 15in wheels that have the same bolt pattern as my dodge dart? |
| Author: | dartsport76 [ Sat Feb 01, 2014 7:46 pm ] |
The torsion bars have to be from an a-body. I've heard 340 bars are a good place to start, especially for a slant car. |
| Author: | alamb [ Mon Feb 03, 2014 11:40 am ] |
okay thanks I'll try and find some. What would you suggest for the rear suspension? If i want to keep it on the cheap. |
| Author: | dartsport76 [ Mon Feb 03, 2014 12:45 pm ] |
I dont know if traction bars (cal-tracs?) hurt your handling, but here's a cheap design http://www.hotrodsandhemis.com/traction1.html Also,I believe 6 leaf springs are the way to go for cheap. I believe 340 darts and dusters came with them. Also there are aftermarket options. |
| Author: | alamb [ Mon Feb 03, 2014 2:49 pm ] |
Why would Caltrac possible hurt my handling? That design you sent me seemed very simple and doable. |
| Author: | slantzilla [ Tue Feb 04, 2014 12:13 am ] |
The bars have to come frim an early A body. Selection will be limited as I am sure they are different than late A body bars. You really need to make a plan as to what you want to do. Are you wanting to drag race or go for handling over horsepower? So far you are trying to make a jumble of both, and you will end up disappointed when you're done. |
| Author: | RumDungeon [ Wed Feb 05, 2014 3:09 am ] |
Quote: The bars have to come frim an early A body. Selection will be limited as I am sure they are different than late A body bars.
Really? I thought the suspension was pretty much the same 63-76?
| Author: | Charrlie_S [ Wed Feb 05, 2014 4:46 am ] |
Are you sure? I thought all "A" torsion bars interchanged
| Author: | slantzilla [ Wed Feb 05, 2014 5:21 am ] |
I thought the early A bodies were a different length? |
| Page 2 of 3 | All times are UTC-07:00 |
