| Timing out of whack https://slantsix.org/forum/viewtopic.php?t=54425 |
Page 2 of 3 |
| Author: | DusterIdiot [ Sun Jan 26, 2014 8:00 pm ] |
| Post subject: | x2!!! |
Quote: I am sorry that the so called engine builder/machinist you went through is clueless. Keep asking questions! and don't give up!
It may seem hard to do now, and just uncomfortable...but when you are done doing these things you will look back and see how far you have come and why you didn't do it sooner, and can comfortably think "What else can I do?" We'll keep answering questions...that's what the board is for!!!! |
| Author: | 1930 [ Mon Jan 27, 2014 2:37 am ] |
Quote: Quote: I would like to change the cam while I am in there, I would like a cam that will give me optimum results for my specific vehicle. How would I go about choosing the correct cam?
The answer to your question is pretty simple for your truck. Doctor Dodge may have built more engine combinations than anybody.....he helped me a lot on mine to get it dialed in since my car is so heavy.Go to the Engine FAQ and read the "Engine Build Matrix" on engine builds and look for mine "Torque Build". That would be a great set up for your truck. I am sorry that the so called engine builder/machinist you went through is clueless. Keep asking questions! and don't give up! I will check out what you mentioned assuming I can find it. Will search tonight. Its Ok on the re-build, whatever, whats done is done. Just another opportunity to learn some new things. As long as the work that I need to do dosent require pulling the engine than I will be OK, if for whatever reason it has to be pulled than things will be a whole different story. |
| Author: | 1930 [ Mon Jan 27, 2014 2:41 am ] |
| Post subject: | Re: x2!!! |
Quote: Quote: I am sorry that the so called engine builder/machinist you went through is clueless. Keep asking questions! and don't give up!
It may seem hard to do now, and just uncomfortable...but when you are done doing these things you will look back and see how far you have come and why you didn't do it sooner, and can comfortably think "What else can I do?" We'll keep answering questions...that's what the board is for!!!! I wont make that mistake again hopefully. Its not like riding a bike, if you dont do this sort of stuff everyday than alot of it gets filed away and its tough to remember the details needed. |
| Author: | Aggressive Ted [ Mon Jan 27, 2014 7:08 am ] |
| Post subject: | Who is Doctor Dodge |
Quote: Who is Doctor Dodge, how do I contact?
Doug Dutra, the man behind this website and one of the most experienced SL6 engine builders. Send him a PM. Read his articles and posts in "The best of Doctor Dodge".....in the Engine FAQ.
| Author: | DusterIdiot [ Mon Jan 27, 2014 3:32 pm ] |
| Post subject: | Yep... |
Quote: As far as removing the head for lifters I have been reading and this is what I found, do you know this too be un-true ?
the holes are bigger and can work to get the lifter through, but difficult is an understatement, a proctologist would have an easier time pulling a lifter out of it's bore then up the lifter bay and then center it to get it through the hole...if they are dumbell shaped and the bores are full of oil sometimes a long nose pliers will be needed to motivate it out of the bore (at that point the head will need to come off.-D.Idiot |
| Author: | 1930 [ Mon Jan 27, 2014 4:18 pm ] |
| Post subject: | Re: Yep... |
Quote: Quote: As far as removing the head for lifters I have been reading and this is what I found, do you know this too be un-true ?
the holes are bigger and can work to get the lifter through, but difficult is an understatement, a proctologist would have an easier time pulling a lifter out of it's bore then up the lifter bay and then center it to get it through the hole...if they are dumbell shaped and the bores are full of oil sometimes a long nose pliers will be needed to motivate it out of the bore (at that point the head will need to come off.-D.Idiot I dont see any reason at this point to consider a solid cam, dont even know yet what is avail for hydraulic. Any recommendations for a cam supplier? |
| Author: | 1930 [ Mon Jan 27, 2014 4:20 pm ] |
| Post subject: | Re: Who is Doctor Dodge |
Quote: Quote: Who is Doctor Dodge, how do I contact?
Doug Dutra, the man behind this website and one of the most experienced SL6 engine builders. Send him a PM. Read his articles and posts in "The best of Doctor Dodge".....in the Engine FAQ. |
| Author: | Charrlie_S [ Tue Jan 28, 2014 3:17 am ] |
OK, new cam and lifters have just been installed and none of it has 100 miles on it, I dont see a reason to replace the lifters again unless I am missing something.
Any time a cam and lifters have been run, they become "seated" together, and the lifters should be kept on the same cam lobes.A new cam, solid or hydraulic, should always get new lifters. |
| Author: | 1930 [ Wed Jan 29, 2014 3:00 am ] |
| Author: | mattelderca [ Sat Feb 01, 2014 10:03 am ] |
Looks to me like one more turn of the crank and the marks are spot on. I would not really blame the person who installed the set for anything. The dots lined up as they should. Whether that is the true, or best timing of that cam is another story. The cam gear should only fit at one point, the crank gear also only fits at one point. That is with a stock non adjustable set. After that you point the dots at each other and put the chain on. If the set itself is wrong no one without the knowledge of that can be blamed. It looks like they put it together right to me. Of course there are different interpretations and instructions given with different sets. Was the instruction on this set to point the dots AT each other? Or was it to align the dots both at 12 O'clock? Or again, was it to align the dots with the darker chain links? And to throw another variable at it, was that set meant for that cam? This is the reason that the experts here suggest getting the cam specs and degreeing the cam properly! Then there is no room for variables. |
| Author: | ceej [ Sat Feb 01, 2014 10:05 am ] |
It's difficult to see what is wrong. Perhaps parallax based on the angle of the camera is hiding it from me. (Your date stamps are September of 2007 by the way.) Are the dots lined up through the centerline of the crankshaft and cam? If so, then the timing set is lined up correctly. The next step is to degree the cam. If it was one of the OEM replacement cams, it is most likely to have events that coincide with the MP244. That is the most common for a mechanical replacement over the counter. To degree the cam may require a different timing set. The one you have is the slotted type on the cam for the cam dowl. If you are going to use cam offset bushings, you will need the type with a hole drilled for the dowl. It needs to be drilled to accept the bushing. If you have the engine out at this stage, pull the head. Put an indicator on the deck and absolutely identify TDC. I wouldn't worry too much about the cam break-in, just so long as the engine didn't spend much time at idle speed during the procedure. That's the killer. CJ |
| Author: | DusterIdiot [ Sat Feb 01, 2014 10:59 am ] |
Figured... You might line up the dots as others have said and put the degree wheel on and see where things line up...if the numbers look good, you can button it up and take a ride (it should feel MUCH better at that point)... If you maintained 2000 rpm for the 20 minutes etc...the cam and lifters should be OK. If adjustments need to be made (i.e. off set bushings)...you can note the distance from the center of the gear to the cam dowel, then remove the gear and scribe a line through the slot and the center of the gear, then drill a new hole on the opposite side of the gear in line with the slot...the dots will be irrelevant at that point but you can now redegree the cam and bush it to match. Quote: Of course there are different interpretations and instructions given with different sets. Was the instruction on this set to point the dots AT each other?
It's an SA stock replacement gear set so the dots should point at each other like the stock sets, if installing the set on a "stock" engine...these don't come with instructions in them just the gears and the chain with the expectation that the dots get lined up and you're done...-D.Idiot |
| Author: | 1930 [ Sat Feb 01, 2014 11:38 am ] |
I guess maybe I am jumping the gun than but this is how the timing marks should appear according to my FSM
| Page 2 of 3 | All times are UTC-07:00 |
