problem when warm
https://slantsix.org/forum/viewtopic.php?t=54572
Page 2 of 2
Author:  Boncky [ Fri Feb 21, 2014 12:22 pm ]
when I set up the ignition timing, i saw that coming out of the ignition 2 wires are not insulated and do gentle touch, I could not stop the car, heaps of cables permanently, auto died and burned condenser coil, I fixed everything but the condenser still burns
what have I done :/[img][img]http://images64.fotosik.pl/682/3f19ee33ae40dd8bm.jpg[/img][/img]
Author:  WagonsRcool [ Fri Feb 21, 2014 1:05 pm ]
If that condenser connects to the (+) side of the ignition coil, then it is a "noise filter" - a capacitor that reduces electrical interference from the ignition to improve radio reception. If yours gets hot then it's likely shorted- you can leave it off.
Author:  Boncky [ Fri Mar 28, 2014 12:54 pm ]
problem solved ! the voltage across the inigiation coil when was connected 6,5 V, somewhere lost the Volts... I have given a "+" from the battery and everything works ! ;]
Author:  oldskoolracer [ Fri Mar 28, 2014 4:40 pm ]
6.5v is about normal across at the coil. There is a ballast resistor on the firewall (white ceramic block with flat terminals on each side, and blue wires going in and out of it)... Replace this if you havnt already. Dont know how that hasnt been mentioned yet...
Page 2 of 2 All times are UTC-08:00
