| Weber on Supersix pics and the setup https://slantsix.org/forum/viewtopic.php?t=54617 |
Page 2 of 3 |
| Author: | Serj22 [ Sun Feb 16, 2014 6:56 pm ] |
I got the Holley regulator as well. It does seem the fuel pressure as-is is excessive. I'll attach it once it gets here on Tuesday. |
| Author: | Wvbuzzmaster [ Tue Feb 18, 2014 9:51 am ] |
Quote: Quote: Serj,
I can take a picture of whatever you need. Do you mean where the kickdown rod passes under the firewall? Or a view as if the firewall is taking a picture of the rod? Let me know I'll get it for ya.Do you happen to have any additional angles showing the kick down on the lower section of the firewall. My 1966 Dart is different in that area. I don't know that I can hook it all up like you did or if I will need to use cables instead. |
| Author: | Kidd [ Tue Feb 18, 2014 8:45 pm ] |
Cool info.....and I like the purple engine. My 440 in my 70 Road Runner is purple! |
| Author: | Wvbuzzmaster [ Tue Feb 18, 2014 9:03 pm ] |
Serj, After looking at your pics I can see my 66 definitely has some way different kick down linkages. Yours looks to be behind the starter mostly. Mine is all on the lower part of the firewall. Might not be a bad thing if I can just mate it all together somehow... Definitely with my Dart sitting up 3 feet off the ground on the car lift currently doesn't make it easy to reach anything to see what stuff does what haha. Besides that, if I actually had someone touch the pedals to see what moves what it might make more sense. Guess until I get all the parts in my hands and the engine rebuilt next winter I will not fully understand how to make the carb swap work out. I do know it is possible though. |
| Author: | Rug_Trucker [ Sun Feb 23, 2014 6:57 am ] |
Thanks for the posts on this. I love the purple. That fuel filter is very scarey. Why in Hell they allow that company to keep marketing that POS is a mystery to me. If it is glass? It can break. If it is plastic? Ethanol will crack it. I worked with a guy that burned his '69 Chevy truck with one of those filters. |
| Author: | Serj22 [ Sun Feb 23, 2014 7:15 pm ] |
I had a plastic one, and ditched it. This one is glass. It's got two soft hoses on either side. I guess it's possible it could break, but I don't know. I'm assuming if it does, the carb will starve, then some gas will fall down to the ground. It's nowhere over the engine. I don't know though. Had this one about a year. I'm more frightened of the Fuel pressure regulator to tell you the truth, because I've heard horror stories of those causing issues - at least it's also not a triangle of death too. I might swap it for a blingbling chrome one. They are cheaper anyway. |
| Author: | Fopar [ Sun Feb 23, 2014 8:51 pm ] |
How much fuel will be pumped before the carb runs dry Richard |
| Author: | Chuck [ Thu Feb 27, 2014 10:20 am ] |
Wvbuzzmaster, On a pre-67 A-Body, you would probably be better off to change the pedal linkage to the cable type. I did this on my 63 Dart when I went to a Super Six setup. You remove the pedal from the floor and all the rod-type linkage that went to it and replace it with the whole setup from a 67 or later car, or even a B-Body. I think I only had to drill one hole in the firewall to mount it up. Then you can use just about any carb. Here is a picture of the original linkages. I believe the cable-type in the lower picture is from a B-Body. I don't have a picture of the later "hanging" type pedal that I used.
| Author: | Serj22 [ Sat Mar 01, 2014 12:31 pm ] |
Well another update. I set timing to 12 degrees initial. The car ran beautifully on the freeway today. 15miles each way at 70mph. I feel like the car was bogging before at 8btdc, this Weber definitly operates better at more advanced. |
| Author: | Aggressive Ted [ Sat Mar 01, 2014 3:56 pm ] |
That is a pretty typical when you run 12 degrees. The SL6 engines loves more timing and has a nice spunky feel. Something I learned many years ago and highly recommend. |
| Author: | Serj22 [ Mon Mar 10, 2014 8:41 pm ] |
Well, after 3 weeks, I'm going to go ahead and report that the jets used in the carb setup for the jeep kit are adequate, and I see no need to change them. 4psi is the way to go for fuel. If you drop it to 2.7 or lower the carb acts like it's choke never pulls. I can't really explain it, but it drives bad. At 4psi seems perfect - any more and you can pull the egr, or egr block off plate and watch fuel spill out, and smoke will come out of the carb on shutoff (typical too much pressure issues). I will say that it gets 18-20mpg doing 60% freeway driving if you keep your foot out of it, and max out at 65. I have 2.73 gearing in the rear, and a 3spd auto. 12 degrees initial advance seems perfect as well. One thing for the people looking to go Supersix - I'd say this is a much cooler, but not stock looking - option. It definitly has some getup and go. I went with the 38/38 based on the idea that it was a similar size comparably to the Carter BBD, though I believe it flows a lot more air. The total cost I paid and parts needed to convert my 1968 /6 to a Webersix38, was: -Jeep CJ Weber 38/38 kit(electric choke) $320 -Supersix intake $150 -Holley Fuel pressure regulator $25 -Fittings for fuel pressure regulator $20 -Stronger return spring $3 Everything else was already in/on the car, and if you have a cable type throttle, and a stock kickdown that's similar, this swap will literally take about an hour or so, because I already figured out the linkages for you. I'll make a full write up and drawings if anyone's interested. I just like it when information like this is readily available for someone who wants to do it. Also the weber sounds a lot better than an open element Holley 1920. HEre it is: https://www.youtube.com/watch?v=hbUFneYbj-s |
| Page 2 of 3 | All times are UTC-07:00 |
