the nearly black art of compound turbos...
https://slantsix.org/forum/viewtopic.php?t=55201
Page 2 of 3
Author:  dwrlhcaz [ Sun Apr 27, 2014 9:46 am ]
This is his car!
Author:  dwrlhcaz [ Sun Apr 27, 2014 9:50 am ]
So with that said..i WILL go ko3 into to4b..here we go...!!! I may upgrade to a ko4 compressor side down the road depending on IAT..which is useually better in compounds at anygiven load or boost.
Author:  dwrlhcaz [ Sun Apr 27, 2014 11:35 am ]
Some mockup/test fitting...will be gusseted and turbos "hung" by hiemed braces...
Author:  dwrlhcaz [ Sun Apr 27, 2014 11:36 am ]
Ran out of argon...small town problems..should have this potion welded and wategate vband on by mid week
Author:  dwrlhcaz [ Wed Apr 30, 2014 10:24 am ]
Some 2d cad rendering im workin on for some cnc'd plasma cut sheet steel exhaust/turbo manifold components..i didnt like the packaging of my tube headers and want to do a turbo manifold similar to the sheet aluminum intake i made..Image
Author:  dwrlhcaz [ Wed Apr 30, 2014 12:53 pm ]
Im refamiliarizing myself with solidworks and am using draftsight for my 2d plasmacam stuff...going to try to aquire a SLA-3d printer in the next year..i hope to unviel some amazing slant six prototypes soon after...ive got vision for days and days.
Author:  dwrlhcaz [ Thu May 01, 2014 9:01 am ]
Off to cnc plasma guy...
Author:  dwrlhcaz [ Mon May 12, 2014 6:15 pm ]
Been busy..hence quiet..been knockin out some chassis work..
Im still a believer in compounds..but ive decided on my previous m90 plans..i just didnt want to deal with potential exhaust/turbo interface problems in the remote desert in which i roam..maybe ill pull it off on a streetcar in the future..but do stay tuned....ive got a really trick blower
Setup well under way..ill post pics on completion..heres my rear end for you all to look at for now..Image
Author:  AndyZ [ Mon May 12, 2014 9:49 pm ]
A few years back, Hotrod mag did a spot on a 6 turbo in series. Something like 1700 hp out of a 2 litre VW if memory serves.
Your project sounds like a fun one. Do you have a motor yet? What do you have or are planning on building to take this power?
Be sure to post pics when this does start up.
Author:  dwrlhcaz [ Tue May 13, 2014 10:48 am ]
Thanks..it should be fun..yeah ive got a pair of 225s..one cast/one forged..this one will be a cammed stock.cast crank shortblock..head studs, oringed, ported by I with stock valves....remote mounted m90, blow thru cv's on my own sheetmetal intake..
Author:  dwrlhcaz [ Mon May 26, 2014 11:36 am ]
Edit
Author:  dwrlhcaz [ Mon May 26, 2014 11:39 am ]
Edit
Author:  dwrlhcaz [ Mon May 26, 2014 11:40 am ]
Edit
Author:  dwrlhcaz [ Mon May 26, 2014 11:45 am ]
Author:  dwrlhcaz [ Mon May 26, 2014 11:48 am ]
Page 2 of 3 All times are UTC-07:00
