It is currently Sat Nov 28, 2026 9:11 am
Post new topic  Reply to topic  [ 17 posts ]  Go to page Previous 1 2
PostPosted: Thu May 22, 2014 3:45 am
That's assuming the proper size fuse is being used. I've seen too many people use a larger than required fuse to mask other issues, or because a "professional" said to. Better question is if the amp is 5000 max or rms. Mono block, dual channel, multiple channel, bridged, how many watts are the subs, 4 ohm, 2ohm, svc, dvc, are they gonna try to pull a full 5000w load? Again, too many variables to go by than just asking fuse size.
And yea a true 5000w system is gonna be on a whole nother playing field when it comes to wiring, installation, and insulation...
"if it aint broke, fix it till it is"
78 Plymouth Volare Super Six wagon
89 Volkswagen Golf GTI 16v
92 Chevrolet K1500 5.7
98 Ford Escort ZX2 zetech
 Post subject: Fuse, deadner, wiring...
PostPosted: Fri May 23, 2014 2:53 pm
Ive got a 150 amp fuse running 1/0 wire to the capacitor. Then some solid copper 8 gauge to the amp. The amp is not a true 5000 watt, only about 350 to each sub rms. Im looking to upgrade soon. Its 2 channel by the way. I also added a 100 amp alternator, lights and subs pulled too much and made the stereo shut off at idle.
