lack of power
https://slantsix.org/forum/viewtopic.php?t=5547
Page 2 of 2
Author:  83Ram150dude [ Thu Apr 24, 2003 10:34 am ]
A manifold vacuum gage could diagnose a clogged catalytic converter. If the converter is clogged real bad your vacuum reading won't jump as high when you decelerate and be lower than normal at idle. If it were my vehicle I would splice in section of pipe where the converter is and road test it. If its not your converter just splice it back in. My method of splicing is to get a piece of pipe with the same inside diameter as the outside diameter of your exhaust and some muffler clamps.
At what speed do you get the "bog" or hesitation and is it already in drive(if automatic)? If your kick down rod isn't adjusted right it might be up shifting to early. Hope this helps.
Good luck
D150
Well, its an A833OD 4spd, not an auto, so the kickdown would be ruled out. Pretty much doesn't matter what speed. It occurs in every gear, but most noticable in OD4th. Hmmm, that's right, vacuum gauge! Should have thought of that first. Doh!! I'll try that and see where it leads me.
Author:  83Ram150dude [ Thu Apr 24, 2003 11:43 am ]
hey,
Well mine was horrible with the lean burn for after 3/4 throttle, After swapping the old style ignition, and cutting out the cat and getting a free flowing muffle my MPG went up and the power/drivability increased noticably.
Justin
Did you do the swaps all at once, or one at a time? What worked first?
Author:  Super6 [ Thu Apr 24, 2003 12:03 pm ]
You are best off only changing one thing at a time. This way you will always know "what made it better" or can always easily change things back to the way they were if problems become worse.
Another thought i had on this, albeit unlikely, is perhaps your coil is weak and not providing a hot enough spark at higher rpms. If you have a known good coil to try out i would do that next.
Have you made any determination on the cat yet?
Author:  83Ram150dude [ Thu Apr 24, 2003 12:50 pm ]
No determination on the cat yet. As a matter of fact it's pouring rain out off and on today. I'll probably check it out this weekend. Keep you all posted.
Oh, and to Justin's response, I was looking to see if his was all leanburn, cat, or a combination there of.
As far as coil, I hadn't even thought of that. It is original, only has 70k on it, but is 20 years old. Maybe.....hmmm, I'll check that out too.
Gotta break out the tools this weekend I think. :P
Author:  83Ram150dude [ Thu Apr 24, 2003 6:22 pm ]
Well.......the cat is fine. Checked using a vacuum gauge. 22" Hg at idle, as a matter of fact good vacuum across the board. The gauge held steady and didn't drop. Also, the vapor out the pipe turned out to be just that.....water vapor. The smell seems to be more on the HC side now, might be slightly rich at idle. So now I'm thinking the bog is being caused by the Leanburn system. I think the best thing I can do at this point is to convert it with the MP electronic ignition conversion kit. When doing this does the carb need to be swapped too? It's not a feedback type carb, but would it be jetted too lean? Its a Holley 2280, not the original to the truck, but it is a Holley Reman carb. So I'm not sure if it's for the application or not. I thought in '83 they only used the Carter BBD, but I could be wrong. Can anybody shed some light?
Author:  87Slant_sickness [ Fri Apr 25, 2003 10:33 pm ]
Nope, did it all at separate times :)
First off i cut the CAT out, it made the engine run alittle better any you could tell it made a little difference, the next step was to swapp the lean-burn out, this pretty much did it all, set the timing at 12* advanced and it was good, did the muffler out later because my old one was done, other mods consisted of using a clutch fan, and hooking up the EGR (powergoes down, milage goes up)
Justin
Author:  d150ram [ Sat Apr 26, 2003 6:48 am ]
If your throttle solenoid is grounded past idle your distributer won't advance. Have you checked your timing with a timing light? Super 6 made a good point about a weak coil. Some body also may have installed the wrong coil. My 85 uses one with an internal resistor an no ballast resistor.
I had problems on my truck with low coil voltage. It was a combination of a weak alternator (new from Autozone) and poor grounding. Compare your Battery voltage with coil voltage with the engine running and the lights and all electrical accessories on. I think some of these trucks had a problem with the amp gauge causing a lot of resistance in the system. I noticed the one on my truck was deactivated.
I built a backup ignition system for my truck using a vacuum advance distributor and GM HEI ignition module. It took 10 minutes to install. For my emissions test I will re-install the old distributor along with the catalytic converter and air pump. Good luck !
D150
Author:  83Ram150dude [ Sat Apr 26, 2003 2:38 pm ]
Throttle solenoid? Ummm, mine doesn't have one. The more I'm checking this truck out, the more I'm finding by-passed or removed. I think its also missing the air charge temp sensor and the egr solenoid. I think I've gotta pay a visit to the junk yard soon and find a fairly complete /6 leanburn truck, do some studying. Maybe after replacing these items the truck will run the way its supposed to.
Author:  83Ram150dude [ Tue Apr 29, 2003 3:49 pm ]
OK the Ram is finally fixed! And you know how stupid a thing it was? Air charge temp sensor was missing! I replaced it (cost all of $15) and now the bog is gone. Not a real powerhouse by anymeans but drivability is back. The computer must have been in "limp-home" mode for years! Now it sees what it needs to see and runs decent. Thanks for everyone's input on the subject. :D
Author:  87Slant_sickness [ Tue Apr 29, 2003 4:37 pm ]
Glad its fixed :)
Author:  Ice Titan [ Thu Sep 04, 2003 12:49 am ]
Sounds like a route for me. But I think my problem might actually be slightly more extensive. After running my '83 D150 about 75mph for 15 min and stopping at a fast food restaurant, I noticed smoke coming up around the cab. When I parked, I found the cat glowing bright red. I have a slight oil leak so I assume most of the smoke was from the oil being burned on the cat. The muffler man said I was dumping too much fuel into the exhaust causing this. The carb was recently rebuilt. I would hope the shop did it right.
Since I live in a county that requires the sniffer, I'm not sure if I can legally replace the lean burn ignition.
Page 2 of 2 All times are UTC-08:00
