It is currently Tue Jun 23, 2026 2:03 am
Post new topic  Reply to topic  [ 16 posts ]  Go to page Previous 1 2
PostPosted: Fri Jun 13, 2014 12:08 pm
6 Pack Dart
If the timing mark is lined up with the "0" or TDC mark on the timing tab, then yes, the engine will be at TDC on cylinder #1. The problem is that if you go solely by the timing mark you haveonly a 50% chance of being at TDC on the compression stroke.
To quote Reed
#1 & #6 are both going to be at the top at the same time, so watch the valves to be sure you have #1 at compression not #6 (they are 180 degrees off each other)
Richard
