| Engine timing help and answers https://slantsix.org/forum/viewtopic.php?t=55556 |
Page 2 of 2 |
| Author: | Fopar [ Fri Jun 13, 2014 12:08 pm ] |
If the timing mark is lined up with the "0" or TDC mark on the timing tab, then yes, the engine will be at TDC on cylinder #1. The problem is that if you go solely by the timing mark you haveonly a 50% chance of being at TDC on the compression stroke. To quote Reed #1 & #6 are both going to be at the top at the same time, so watch the valves to be sure you have #1 at compression not #6 (they are 180 degrees off each other) Richard |
| Page 2 of 2 | All times are UTC-07:00 |
