Slant Six Forum https://slantsix.org/forum/ |
Offy cover breather question https://slantsix.org/forum/viewtopic.php?t=55630 |
Page 2 of 2 |
Author: | 65 dartman [ Sun Jul 06, 2014 6:21 pm ] |
Post subject: | |
Quote: BTW: I don't intend to discourage you, but you may have been too creative when it comes to baffles, remember that you have to use the front opening for oil filling as well. Olaf |
Author: | olafla [ Mon Jul 07, 2014 7:58 pm ] |
Post subject: | |
That's what I call an engine cradle, very nice setup! BTW, one of the big aussie suppliers of slantsix goodies, cannot remember their name, also have some nice cast ribbed aluminum pieces that matches the Offy valve cover quite good, like air cleaner lids and breathers. Quote: ...the stock early A valve covers had baffles under both stovepipes.
I just reacted to the limited size of the openings each side of the baffle. I don't have a baffle under the oil filler cap on my '77 engine, but there are 3 holes in my cover, as opposed to 2 in the earlier ones. There are baffles under the other 2 holes, one holding the pcv-valve on a raised portion of the cover, and the breather at the rear end. A catch can is a good idea on any engine, but especially on engines with somewhat limited oil-free breathing space. The life of the pcv-valve is also increased, by reducing possible clogging when it is removed from the worst hot oil mist. Olaf |
Author: | ridehard [ Thu Jul 10, 2014 2:07 am ] |
Post subject: | |
Sure, I will get some more pics and a few measurements this weekend. Was built for the slant but also have plenty of adjustments so should fit most engines with a few more holes drilled. I used a bellhousing and flywheel from manual transmission to mount the starter, just for running in. Got a 904 for the car. |
Author: | 1930 [ Tue Aug 19, 2014 1:18 pm ] |
Post subject: | |
Thanks for posting these pictures, did you build this. I am going to go ahead and make one for myself. You car looks goo as well BYW EDIT: the more I look at it the more the blue reminds me of other equipment I have that looks similar so Id guess only parts of it are fabricated by yourself. What would you like to see changed about it if you could change things. Id like to improve on the design if I could. |
Author: | ridehard [ Wed Aug 27, 2014 4:59 am ] |
Post subject: | |
Yep all fabricated by my dads mate and I. If I had to change anything I would shorten the overall length and put swivel wheels in each corner. Depends on your space really, ours is limited. This can disassemble and flatten for storage and is adjustable to suit most motors. Will just need a few more holes drilled here and there if I want to put a v8 on there at some stage. Also I wish I painted it before I put the motor in, getting a bit of surface rust on the welds. I suppose that just makes me want to put it in the car sooner though. Still needs a bit of a tune up and adjust the valves once it's hot but I'm pretty happy with how it runs so far. Here's a little vid. http://youtu.be/gYV7yzDPaik |
Author: | 1930 [ Thu Aug 28, 2014 3:22 am ] |
Post subject: | |
Quote: Yep all fabricated by my dads mate and I.
Sounds really good, I am also building one I hope to have it finished over the weekend. Using your ideas
Author: | ridehard [ Thu Aug 28, 2014 4:58 am ] |
Post subject: | |
Looking really good. Keen to see the progress and an engine on there when it's finished. Nice work. |
Author: | '67 Dart 270 [ Sat Aug 30, 2014 9:09 am ] |
Post subject: | baffles |
On Olaf's baffle issue, I had an older offy with baffles on both stove pipes and it made putting oil in a question of patience. My new cover doesn't have the baffle in the front and due to the air flow there is no oil leaking at all and I can dump 5 quarts in there real fast (for those times I decided to change the oil just before dinner)...btw I do use a PCV cap and a catch can at the back, works wonderfully, I put a stop cock in the base of the catch can (I used a large aluminum fuel canister). In the picture below you can see the catch can on the firewall just below and left of #6 plug. http://s785.photobucket.com/user/67dart ... ort=3&o=84 The above pic is of the older offy cover, the one below is the dual stove pipe design with no baffle in the front stove pipe http://s785.photobucket.com/user/67dart ... f.jpg.html You can just see the top of the catch can in the lower left of this pic. And yes, your engine stand is amazing... bg |
Author: | olafla [ Sat Sep 06, 2014 9:25 pm ] |
Post subject: | |
'67 Dart 270, I have yet to hear about a well planned catch can setup that didn't work as intended, you just confirm that the concept is sound! The engine stand is great, but ridehard's engine and attention to smart solutions is also impressive, and I must say that the workmanship and attention to details on your car and engine, is pretty amazing too! Olaf |
Page 2 of 2 | All times are UTC-08:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
