| FInding a Super Six https://slantsix.org/forum/viewtopic.php?t=55893 |
Page 2 of 2 |
| Author: | Reed [ Sat Aug 02, 2014 5:03 pm ] |
$250 is a bit steep, unless the carb is in good working order. At least the carb appears to be a correct slant six BBD. I don't see the Super Six specific choke thermostat or throttle return spring bracket or kickdown linkage. He can keep the distributor and the exhaust manifold (unless you want an extra exhaust manifold or yours is damaged). For those parts I think that $150 plus shipping is more in line. |
| Author: | Serj22 [ Sat Aug 02, 2014 6:10 pm ] |
I paid $150 alone for my supersix intake, and was only lucky enough to get the air cleaner for free. You pay about $10 to get the reproduction sticker, and the carbs come up a lot for $20ish. The kickdown is the setback, usually people want $100-$150 for that. You don't need the exhaust manifold. |
| Author: | Reed [ Sat Aug 02, 2014 7:22 pm ] |
Kickdown = cable style kickdown (less than $30 on eBay) Air cleaner = stock 318 two barrel air clenaer (should be piles of them at swap meets and junkyards) + reproduction sticker |
| Author: | 1930 [ Sun Aug 03, 2014 3:39 am ] |
Quote: He is offering for the air cleaner, carb (supposdly rebuilt) and intake 250 plus shipping, you think it is a fair price? I have no idea what stuff is worth.
In my opinion saying the carb is re-built and selling it as a re-built carb means nothing. I always assume the carb has to be re-built again and unless you can hear an engine running with that carb installed than I would assume the same. If you are planning to run A/C than keep in mind that there is a special air cleaner with an A/C provision molded into it on the bottom of the air cleaner base and you will need this specific cleaner if A/C is in your future. I think 250 is high, I would pay 175-200 if I still needed those parts cause at least you get a few keys parts all in one swoop. |
| Author: | 1930 [ Sun Aug 03, 2014 3:42 am ] |
Quote: I paid $150 alone for my supersix intake, and was only lucky enough to get the air cleaner for free. You pay about $10 to get the reproduction sticker, and the carbs come up a lot for $20ish. The kickdown is the setback, usually people want $100-$150 for that. You don't need the exhaust manifold.
Where can I get a carb for 20 ish. I would like some spare to play around with and for parts? Ill assume E-bay but what would be the search words I would use? |
| Author: | 1930 [ Sun Aug 03, 2014 3:43 am ] |
Quote: Kickdown = cable style kickdown (less than $30 on eBay)
I must have misunderstood a previous post you had made. I thought the air inlet was a different shape on the slant air cleaner versus the 318 cleaner. Air cleaner = stock 318 two barrel air clenaer (should be piles of them at swap meets and junkyards) + reproduction sticker I know he prob. does not care about this but can you re-fresh my memory? |
| Author: | chongo25 [ Sun Aug 03, 2014 8:20 am ] |
Ok thanks for the advice, I guess if he doesn't come down on price I would probably skip. |
| Author: | chongo25 [ Sun Aug 03, 2014 8:24 am ] |
Quote: Quote: He is offering for the air cleaner, carb (supposdly rebuilt) and intake 250 plus shipping, you think it is a fair price? I have no idea what stuff is worth.
| Author: | Serj22 [ Sun Aug 03, 2014 8:52 am ] |
Not ebay. People think their Carter BBD's are made of gold on Ebay. Check here in the wanted section, or Fabo. Whitepunkonnitro on that site has a few I think. |
| Author: | 1930 [ Sun Aug 03, 2014 9:32 am ] |
Quote: Not ebay. People think their Carter BBD's are made of gold on Ebay. Check here in the wanted section, or Fabo. Whitepunkonnitro on that site has a few I think.
Ok yes gold, that is what I have noticed as well. Thanks
| Author: | 1930 [ Sun Aug 03, 2014 9:34 am ] |
Quote: Quote: Quote: He is offering for the air cleaner, carb (supposdly rebuilt) and intake 250 plus shipping, you think it is a fair price? I have no idea what stuff is worth.
| Author: | chongo25 [ Sun Aug 03, 2014 6:30 pm ] |
Haha, trust me im not take that bad boy out. I will keep it a Slant 6 no matter what. I'm just trying to add some fun to it. |
| Author: | Reed [ Sun Aug 03, 2014 9:47 pm ] |
Quote: Quote: Kickdown = cable style kickdown (less than $30 on eBay)
| Author: | 1930 [ Mon Aug 04, 2014 3:12 am ] |
Quote: Quote: Quote: Kickdown = cable style kickdown (less than $30 on eBay)
I must have misunderstood a previous post you had made. I thought the air inlet was a different shape on the slant air cleaner versus the 318 cleaner. Air cleaner = stock 318 two barrel air clenaer (should be piles of them at swap meets and junkyards) + reproduction sticker I know he prob. does not care about this but can you re-fresh my memory? I believe the difference was that the correct super six cleaner had the round end on the air inlet and the 318 was more rectangular ( I believe that is what you told me earlier ) but I may be off. |
| Author: | 63gtcv [ Tue Aug 12, 2014 5:33 pm ] |
Look in the parts for sale section. Super six set-up, $200. AS far as a cleaner base goes, Mine is from a 67 Belvedere. Got lucky. And the super six lid fits nicely. |
| Page 2 of 2 | All times are UTC-08:00 |
