| Should I mess with it? https://slantsix.org/forum/viewtopic.php?t=55904 |
Page 2 of 3 |
| Author: | Danarchy [ Tue Aug 05, 2014 9:19 am ] |
Quote: Before you try to break the nuts loose spray the crap out of them with PB Blaster for a couple days. You'll be glad you did. Quote: PB Blaster is your friend. Quote: ....what he said +1,2,3..?
| Author: | Doctor Dodge [ Tue Aug 05, 2014 10:30 am ] |
As an FYI, it's the 2 end positions that are a concern... the iron conical washer in the centre position looks correct. http://www.dutra.org/doug/draft-webpage ... ctions.htm I'd spray and wire brush the exposed threads and then carefully try to unscrew the nuts... using 2 wrenches on the "double-nut" set, to get the top nut off first. To be honest.. I would leave them alone IF they do not come-off easily with light effort. (if needed, go break some studs off a junk head, to get a "feel" for it) If you can get them off, replace with the correct brass washers and locking nuts. The contact surfaces should be smooth to allow for sliding action as the manifold heats & cools. DD |
| Author: | nm9stheham [ Tue Aug 05, 2014 12:09 pm ] |
On the topic of brass nuts, it used to be common to use them on exhaust to manifold flange bolts. It is still a good practice to use them on any exhaust fastener that you want to remove intact some time later. |
| Author: | 1930 [ Tue Aug 05, 2014 1:41 pm ] |
Good call and I have read this ( printed and saved ) but I believe alot of this stuff was written quite a few years ago and of course things have changed, maybe a better way/step has come around. Thats why I ask sometimes what might seem obvious.
| Author: | 1930 [ Tue Aug 05, 2014 1:43 pm ] |
Quote: As an FYI, it's the 2 end positions that are a concern... the iron conical washer in the centre position looks correct.
Im going to go out there in abit and try and loosen them, I bet they will come right off but will let you know either way how I make out. Thanks
| Author: | 1930 [ Tue Aug 05, 2014 1:44 pm ] |
Quote: On the topic of brass nuts, it used to be common to use them on exhaust to manifold flange bolts. It is still a good practice to use them on any exhaust fastener that you want to remove intact some time later.
Slantsixdan wrote a good post about the brass hardware, I cant seem to find it right now but I am hoping I will, covered all the part numbers to get the good stuff.
| Author: | 1930 [ Wed Aug 06, 2014 3:24 am ] |
Looking again at Docs manifold installation article it states............ The two acorn nuts go on the two top, outer end studs, with the coned shaped part of the nut fitting into the dished/conical part of the round brass washers.............. My brass washers appear identical on both sides, I have even laid a straightedge across the faces of the brass washers and I cant detect a dished/conical side? I see and understand the dished conical steel washer that is in the center position but I see no such thing on these outer end brass washers. Was this part of the instruction maybe intended for an earlier design brass washer? These were pulled from slant exhaust manifolds all hydraulic 81 up manifolds. |
| Author: | Doctor Dodge [ Wed Aug 06, 2014 7:52 am ] |
The brass washers, used on the end studs, are not conical... they are flat-faced, as described. These washers should have an ID chamfer on one side, designed to accept the slotted "cone" on the lock nut. This special nut grips the stud, when the nut is tightened into the brass washer's angled ID. DD |
| Author: | 1930 [ Wed Aug 06, 2014 2:02 pm ] |
Ok I can see that the nut goes in one side further than the other so I understand. Thanks |
| Author: | BUCKET 636 [ Sun Feb 08, 2015 11:56 pm ] |
I have done a search but can't seem to find an answer , sorry about the old thread revival. I am installing extractors/headers on my slant. Do I still need to use the two brass washers and conical nuts on the two end studs ? |
| Author: | Fopar [ Mon Feb 09, 2015 12:44 pm ] |
Not if they are 2 piece yes if they are 1 piece. Richard |
| Author: | BUCKET 636 [ Wed Feb 11, 2015 1:17 am ] |
Quote: Not if they are 2 piece yes if they are 1 piece.
Thanks Richard.Richard Would you class these as 2 or 1 piece ? As you can see all six pipes go to one collector but the front 3 and rear 3 pipes are on 2 different mounting flanges , if you know what I mean , so I don't know if they could be considered a 1 or 2 piece unit. I don't know what brand they are as they have no markings .
| Author: | Fopar [ Wed Feb 11, 2015 4:17 pm ] |
Those are 2 piece, look at the head mount plates.The stock manifold is a 1 piece flange and needs to have the extra movement. Richard |
| Author: | '67 Dart 270 [ Sat Feb 14, 2015 6:36 pm ] |
| Post subject: | McMaster Carr |
You can still by the correct brass nuts and the compression or "acorn" nuts at McMaster Carr. All you need is the dished washers that go with the acorn nuts at each end of the manifold. If you PM me, I can find the correct ones for you and give you the McMaster item numbers and/or send you the correct ones. Read DD's install notes first, so you know how to install them. Also, if you are taking the manifolds loose (I agree with the posts that say if it ain't broke, don't bother) for some reason and replacing the gasket use Remflex gasket, it will not leak and provides great crush leeway for the manifolds alignment. brian |
| Page 2 of 3 | All times are UTC-07:00 |
