It is currently Wed May 20, 2026 10:45 pm
Post new topic  Reply to topic  [ 16 posts ]  Go to page Previous 1 2
PostPosted: Sat Aug 09, 2014 3:51 pm
Dan I know you did not say you wanted it but I put that starter and solenoid aside if you are interested.
Thanks for that. I do not have a use for one of these starters right now or in the foreseeable future.
Problem is that this place charges almost as much for these starters/alternators as new parts ( assuming you can buy new ) Anyway I bet the starter would cost 25 dollars plus the shipping to get it to you
New starters tend to cost a couple hundred dollars, if you can get 'em. "Remanufactured" starters, for this application, maybe $80.
Can someone tell me if this early style ( what I am assuming ) PCV valve is a good design
Sure. They've gotten difficult and expensive to buy any more, but you can use the later plastic type of valve: Remove the metal valve and its locknut. Save the 2-legged spring from the underside of the PCV valve "cap" that fits on the valve cover. Make a sandwich in this order: PCV valve (push the non-hose end through the cap from outside to inside), spring retainer, grommet (push onto non-hose end of PCV valve from the bottom). Sometimes the spring retainer won't fit over the plastic valve and you have to leave it off. Push this "sandwich" onto the valve cover chimney. It won't look original, but it'll fit and work fine. The old metal valves can be cleaned and re-used for years, but after awhile they just plain wear out. The spring gets tired, the plunger gets worn, and then they cause poor idling.
It would be easier for you to find a '66-'69 valve cover -- same as the one you show here, with the ridged top, except instead of the rear chimney/cup arrangement for the PCV valve it has the rubber grommet for E-Z snap-in mounting of a metal or plastic valve.
66-69 got it, thanks. Maybe I will get lucky
