| Dutra RV15-RDP cam -- where to buy these days? https://slantsix.org/forum/viewtopic.php?t=56026 |
Page 2 of 2 |
| Author: | Doctor Dodge [ Fri Aug 22, 2014 1:24 pm ] |
Ask for RV15 / 295 RDP that D. Dutra help design with them, back in 2005. The "/ 295" is the master number for the MP 244 exhaust lobe. (They will say that their RV10 lobe is the same ... but it is not, their RV10 is a GM pattern (.84 lifter) with a steeper / shorter lash ramp) DD |
| Author: | SlantSixDan [ Fri Aug 22, 2014 1:34 pm ] |
Real good, thanks -- shall do and I'll report how the call goes. |
| Author: | emsvitil [ Fri Aug 22, 2014 2:54 pm ] |
See http://www.slantsix.org/forum/viewtopic ... 631#412631 |
| Author: | SlantSteve [ Fri Aug 22, 2014 7:36 pm ] |
Russ Yoder Erson Cams Louisville, KY ersoncamsshop@gmail.com www.pbm-erson.com 800-641-7920 ext 8003 (Eric) ext 1041 (Ryan) Worth a try....not even sure if this is the current contact info but who knows,maybe they are able to take one off orders now. If no luck with Erson and you won't buy a Comp Cam then you may have to go "generic". With all the choices out there I'm sure there is something that would work very well. |
| Author: | SlantSixDan [ Sat Aug 23, 2014 2:29 pm ] |
Excellent. We'll see where it leads. I note a long list of clickable cam spec cards on Erson's site; anyone happen to know which of these (if any) might apply? |
| Author: | Sam Powell [ Sun Aug 24, 2014 4:59 am ] |
Dan, Once you get this worked out, is there some way we can register this grind and its specs with a cam company that will keep it on record? Let us know who you use and your satisfaction rate with the process and the product please. I know this was done once before, and the resulting business changes wiped out that progress. It would be nice to have it done again so others can duplicate it without reinventing the wheel each time. Thanks for your efforts here. Sam |
| Author: | 68barracuda [ Sat Aug 30, 2014 10:20 am ] |
Hi Guys, Any update on this? |
| Author: | Feather_Duster [ Thu Sep 18, 2014 9:34 pm ] |
I'm interested too... any update? |
| Author: | SlantSixDan [ Sat Sep 20, 2014 2:26 pm ] |
Haven't had time -- in middle of complicated house move. |
| Author: | spacecommander [ Sun Sep 21, 2014 8:48 am ] |
Quote: Haven't had time -- in middle of complicated house move.
Cutting it up and moving it on trailers or a really big helicopter like a Sikorsky Skycrane? |
| Author: | 68barracuda [ Fri Sep 26, 2014 11:17 am ] |
Hi Guys - so we have 6 months get this sorted - 6 months for the profiles, 3 months to get to me in Sunny RSA, and Three months worth testing before the next Kalahari Speed Week Kalahari Desert Speedweek Check the slant Barracuda it hit a indicated 90mph was measured at 140kph |
| Page 2 of 2 | All times are UTC-08:00 |
