Slant Six Forum https://slantsix.org/forum/ |
How Would You Fix This Manifold Issue? https://slantsix.org/forum/viewtopic.php?t=56125 |
Page 2 of 2 |
Author: | mattelderca [ Mon Sep 08, 2014 5:39 am ] |
Post subject: | |
Quote: Rather than make a threaded insert with an NPT plug, just buy a threaded insert..................
Timesert, also very good for spark plugs.http://www.timesert.com/ |
Author: | 63valconvert [ Mon Sep 08, 2014 8:54 am ] |
Post subject: | Query |
Thanks everyone. Pretty sure the manifolds were BOTH machined as a stack, so that shouldn't be the issue (especially with the thick Remflex). One thing, though: if I find a "leaking runner" with carb cleaner, what do I do? Tighten the nuts around it? Does it make sense to have different torques? |
Author: | Rick Covalt [ Mon Sep 08, 2014 10:00 am ] |
Post subject: | |
If they were both planed together you should be able to just draw them all up evenly, especially with the Rem Flex. Rick |
Page 2 of 2 | All times are UTC-08:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
