| Full suspension rebuild / 64 Dart GT https://slantsix.org/forum/viewtopic.php?t=56773 |
Page 2 of 2 |
| Author: | SpaceFrank [ Tue Jan 06, 2015 6:35 pm ] |
Quote: Do a price comparison between the KYB's and Bilsteins; if not too much more, go for the Blisteins. If a lot, then the KYB's are not too bad.
The KYBs are about $35 apiece. I haven't been able to find a part number for Bilsteins for a '64 Dart, but the QA1s are a little over $100.
| Author: | bilbowman [ Wed Jan 07, 2015 11:01 am ] |
Quote: Quote: Pitman arm is not included... is this something I should be getting?
Depends on how sloppy your steering/suspension is now, and if you want it to be easier to replace, because you are already there with everything out of the way!Think this one will do it? http://www.ebay.com/itm/ACDelco-45C1002 ... ab&vxp=mtr |
| Author: | bilbowman [ Fri Jan 23, 2015 10:23 am ] |
Hi everyone, Suspension rebuild on the '64 Dart GT is complete! Car no longer squeaks, doesn't bottom out on bumps and dips and the handling is very much improved. One thing that I was surprised by was that there was no sway bar, which was surprising since a couple of people on this thread suggested I upgrade the bushings to poly. Thoughts? Going to a swap meet this weekend to hopefully pick up some wheels to replace the stock 13's. Any suggestions on what size to go with? Not looking for mags or rally's... I want to keep the car looking relatively classic. Thanks a lot for all of the great info... I'll get some pics up shortly! Cheers, Bill |
| Author: | bilbowman [ Fri Jan 23, 2015 6:28 pm ] |
Quote: Only put poly in the rear leaf bushings and the sway bar bushings, otherwise MOOG or good quality rubber everywhere else.
The Dart didn't have a sway bar installed. Did they not come stock?Lou Thanks, Bill |
| Author: | SpaceFrank [ Fri Jan 23, 2015 6:49 pm ] |
I don't know about the Dart GT, but my base model '64 Dart didn't come with one stock. |
| Author: | emsvitil [ Fri Jan 23, 2015 6:49 pm ] |
No sway bars in 64 as standard. (maybe optional, but don't think so) My 64 Valiant didn't have any either. I added 1 1/8 front 3/4 rear. |
| Author: | curmudgeon [ Fri Jan 23, 2015 11:05 pm ] |
Quote: "No sway bars in 64 as standard.(maybe optional, but don't think so)"
In March of 64 I ordered a new Dart GT with a 273 and 4 speed and was told sway bars were not an option. Fred |
| Author: | Danarchy [ Sat Jan 24, 2015 4:44 pm ] |
Sway bars were not optional in 1964. Looking for wheels? You know the 13's are a 5x4 bolt pattern,don't you? Not alot of options out there! If you are sticking with the original pattern, I would suggest moving up to 14" wheels. Somewhat better tire selection. |
| Author: | standjoh [ Wed Sep 14, 2016 7:40 pm ] |
I am new to the A body slant 6 group!! I just picked up a 1965 Dart GT and can't seem to find anyone that sells sway bar bushings??? Does anyone know where or if these things are available???? Thanks John |
| Page 2 of 2 | All times are UTC-07:00 |
