It is currently Wed Dec 11, 2024 1:23 am
Post new topic  Reply to topic  [ 16 posts ]  Go to page Previous 1 2
PostPosted: Wed Jan 14, 2015 7:50 am
Also, if I remember properly, engine should be warm (at least). Compression losses can be higher when cold, but the engine is going to run hot anyway :).
In a warm engine valves are going to open sooner too (metal rod expansion). Don't know how much difference that can cause.
And after checking some old threads...
http://slantsix.org/forum/viewtopic.php ... test#35932
you should remove the air filter. I'll check that in the service manual when at home.
/6 Dodge Charger 69
Image...there's nothing like using the "Search" link above to solve most of your problems...
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 6 guests
