Slant Six Forum https://slantsix.org/forum/ |
engine Idle affected by water https://slantsix.org/forum/viewtopic.php?t=56904 |
Page 2 of 2 |
Author: | cpslntdchrg [ Wed Jan 14, 2015 7:50 am ] |
Post subject: | |
Also, if I remember properly, engine should be warm (at least). Compression losses can be higher when cold, but the engine is going to run hot anyway . In a warm engine valves are going to open sooner too (metal rod expansion). Don't know how much difference that can cause. And after checking some old threads... http://slantsix.org/forum/viewtopic.php ... test#35932 you should remove the air filter. I'll check that in the service manual when at home. |
Page 2 of 2 | All times are UTC-08:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
