| Exhaust manifold heat control valve question https://slantsix.org/forum/viewtopic.php?t=57268 |
Page 2 of 2 |
| Author: | '67 Dart 270 [ Sun Mar 15, 2015 5:32 pm ] |
| Post subject: | heat shield.. |
Dan, why not sheet metal heat shield? It reflects some heat, and absorbs heat but also dissipates it quickly. Mine is Al. brian |
| Author: | '67 Dart 270 [ Sun Mar 15, 2015 6:44 pm ] |
| Post subject: | sheet metal choice... |
As far as sheet metal choices go, steel absorbs heat more slowly than Aluminum, but also dissipates it more slowly. Both provide a physical barrier to block radiating and convective heat from the engine/manifolds. I suppose a high temp polymer would be even better, like PEEK or something akin to that. PEEK melts at 662 degrees F. brian |
| Author: | '67 Dart 270 [ Sun Mar 15, 2015 6:51 pm ] |
| Post subject: | ...but |
a 12" x 12" x 1/8" sheet of PEEK costs $285.00, while the same size sheet of aluminum costs $20, steel even less. |
| Page 2 of 2 | All times are UTC-07:00 |
