| 3spd to 4spd OD?! https://slantsix.org/forum/viewtopic.php?t=57367 |
Page 2 of 2 |
| Author: | Jerame_c [ Fri Apr 17, 2015 10:28 pm ] |
Here is a pic of my setup. I went with a spacer block to move the mount over which lines up my z bar link. Your setup looks good but I wonder about the lower link rotating after a lot of use and causing geometry issues. Just something to ponder. ![]() http://s1.postimg.org/r1ehgf2hb/2015_04_17_21_54_48.jpg |
| Author: | vntned [ Sun Apr 19, 2015 10:18 am ] |
I pressed the ball stud out of the stock bracket, and welded it into a new bracket I drew up, as well as a few spacers, and had a friend cut them out on a plasma table. I ended up using all three of the spacers, which ended up giving me about 1.25" total thickness. (The pic I posted only has two of the spacers, I added the third to straighten up the clutch rod more) As it sits, my Zbar is level to the ground and doesn't bind up at all. I went ahead and replaced all the bushings, clips and washers. As well as greasing the mess out of it all. The clutch rod is a combination of the stock rod coming off the Zbar, which connects to the 3/8" steel plate I made up, and the rod that goes to the clutch fork is a late A/F body rod that I cut the eyelet off of. That way I was still able to use the correct nut/washer/bushing setup that the clutch fork requires. Like I said, works great so far. Travels smoothly with no binding and not hitting anything. I might pull the clutch rod and weld the nuts in place, to prevent potential slippage. |
| Author: | nm9stheham [ Thu Apr 23, 2015 11:38 am ] |
Dang....that's different! |
| Page 2 of 2 | All times are UTC-07:00 |
