| sealent on waterpump gasket ???? https://slantsix.org/forum/viewtopic.php?t=57405 |
Page 2 of 2 |
| Author: | '67 Dart 270 [ Thu Apr 02, 2015 11:48 am ] |
| Post subject: | good ideas... |
I like both the grease and the hylomar ideas. Grease permeates the paper and makes an effective water barrier, hylomar (and grease) lets you take it back apart without destroying the gaskets. |
| Author: | Nicademas [ Thu Apr 02, 2015 3:02 pm ] |
When i rebuilt my motor 2 years ago I used a Felpro gasket that had an adhesive on one side. You pulled off a cover like you would be pealing a sticker. Never had a leak yet. I attached it to the water pump first and then bolted it up to the block. |
| Author: | '67 Dart 270 [ Thu Apr 02, 2015 4:30 pm ] |
| Post subject: | adhesive... |
Ah! So I was wrong, some do actually come with adhesive. Good to know. brian |
| Author: | Nicademas [ Thu Apr 02, 2015 6:45 pm ] |
Also my thermostat gasket is the same way. Its a Felpro as well. |
| Author: | Sean Mallory [ Fri Apr 03, 2015 9:52 am ] |
| Post subject: | Re: good ideas... |
Quote: hylomar (and grease) lets you take it back apart without destroying the gaskets.
or scraping
| Author: | USAJon [ Sat Apr 11, 2015 9:26 am ] |
here's what I used I also put some on a cheap battery cable that had come loose.it stays stickie for ever, it's used on gas pump connectors. ![]() ![]() ![]()
| Page 2 of 2 | All times are UTC-07:00 |
