Cam info/advice needed
https://slantsix.org/forum/viewtopic.php?t=57471
Page 2 of 2
Author:  DusterIdiot [ Wed May 20, 2015 6:41 am ]
Post subject:  Ok
I'm pretty sure my tire size is 205/60r15 (can't verify right now). Rear end is 3.23
Double check, as it looks like your car in this configuration will be at 2500 rpm in 3rd, and about 1800 in OD at 55 mph.... (1800 won't put you into the main jetting on most normal carbs without some modifications), little over 2000 rpm if going 65...205/60R14 on stock rims will be slightly kinder...
Author:  Feather_Duster [ Fri May 22, 2015 9:50 am ]
I was wrong, but not about the rim size... 205/65R15 is the size. Could change if necessary - tires are pretty old and probably shouldn't be driven. Would stick with the 15" rim though. I went with 205/65 because it was equivalent to the 195/75R14 that was on there.
Would prefer if the speedometer is accurate though.
Page 2 of 2 All times are UTC-08:00
