SL6 eye candy
https://slantsix.org/forum/viewtopic.php?t=57610
Page 2 of 2
Author:  SlantSixDan [ Fri May 01, 2015 9:46 am ]
One thing, though: if you want to keep your engine (i.e., you want it to live a long and happy life), you really will want to figure out some actual air filters. Those K&N things don't qualify as such. They'll keep out spiders, seashells, small children, and chunks of concrete. Actual dust and grit flies right through 'em and into your engine. See here and here. ("…After only 24 minutes the K&N had accumulated 221gms of dirt but passed 7.0gms. Compared to the AC, the K&N plugged up nearly 3 times faster, passed 18 times more dirt and captured 37% less dirt…")
Author:  Reed [ Fri May 01, 2015 10:02 am ]
Was it Pintos and Mustang IIs that used the Holley 5200 and had an air cleaner that will fit Webers?
Author:  BUCKET 636 [ Fri May 01, 2015 1:48 pm ]
Now that is a work of art .
Author:  '67 Dart 270 [ Fri May 01, 2015 4:56 pm ]
Post subject:  Lou's and Dan's comments
Lou, just wanted to mention that I also powder coated my Dutra Duals. I live in a foggy area and my exhaust manifolds would get rust all over them if I didn't drive it for a couple days even. No longer an issue. Yes, I too hope the break in goes well and she runs super.
Dan, absolutely! I've been looking for alternative air cleaners. I used the K&N's because they were the only one's who make a base plate for 32/34 DFT Webers, it's not a nice rectangle, it's a weird shape. Actually it didn't even fit, I had to remove 1mm of material from the hole before it would even fit on the carbs. Short of making my own, there are three other choices I see:
1. I've been trying to find a paper element that'll fit these K&N housings, the K&N part number is E-3442. It's an oval element, but I was thinking I could find a round paper disposable one and work it into an oval shape. It has to be 2" tall or close, and 7 3/8 in diameter to work, but I can't find any size information on anything other than K&N online. If anyone knows how to find such a paper element I'd be glad to hear from you.
2. I just found these, which are also made for the 32/34 DFT: http://ramair-filters.co.uk/rs-carb-fil ... plate.html they use foam as the filter.
3. Finally, there is Weiand, who makes a blank base plate in their 600 series air cleaners, I could cut it using my K&N as a template. I really think these would look great on there, but is the foam any good at stopping dust? There is a US distributor who sells these for $50/piece.
http://www.weberperformance.com.au/inde ... =36_78_207
Brian
Author:  '67 Dart 270 [ Fri May 01, 2015 5:09 pm ]
Post subject:  foam
Dan,
I read the articles you posted, foam, at least the one's they tested was a pretty good filter.
Brian
Author:  '67 Dart 270 [ Fri May 01, 2015 5:23 pm ]
Post subject:  on reread...
..OK, all I got for sure from the article is that K&N are pretty bad at filtering out particles...which is what you said.
brian
Author:  '67 Dart 270 [ Fri May 01, 2015 5:28 pm ]
Post subject:  foam
I know when I service the foam air cleaner on my lawn mower, the intake side of the foam is pristine, no particles or dirt of any kind, while the outside is coated in gunk/dirt.
My K&N's do leave much to be desired. Honestly I think the K&N's are a scam, like razorblades and printer ink. "lifetime" is fine, but it doesn't work well for that whole lifetime.
brian
Author:  '67 Dart 270 [ Fri May 01, 2015 6:01 pm ]
Post subject:  Reed's comment
You could be right, Reed, the 32/34 DFT was used on Ford Fiesta's with a 1.9L 4 banger I believe in the 80's. Not sure what the air cleaner housing looked like though.
brian
Author:  Wesola78 [ Fri May 01, 2015 6:09 pm ]
That looks great!
I have the Dutra front exhaust manifold, and a modified stock manifold.
I would love to have those pipes.
Author:  '67 Dart 270 [ Fri May 01, 2015 6:14 pm ]
Post subject:  foam plus K&N?
Maybe a foam precleaner would help?
http://www.ebay.com/itm/Oregon-30-945-F ... 4ad8695f93
brian
Author:  Rick Covalt [ Sun May 03, 2015 12:25 pm ]
Found a picture of one of Doc's oil pumps. Hope that explains it a little better.
Rick
Author:  '67 Dart 270 [ Sun May 03, 2015 5:27 pm ]
Post subject:  DD gear oiler
Thanks Rick, that's great, can't possibly miss the gear and it's sleek and elegant compared to older models...
brian
Page 2 of 2 All times are UTC-07:00
