It is currently Mon Nov 16, 2026 5:05 am
Post new topic  Reply to topic  [ 17 posts ]  Go to page Previous 1 2
PostPosted: Sun Nov 29, 2015 4:50 pm
Car Model: 1960 Valiant
So the car has been running great and it's getting a lot of use. Still haven't got around to doing the HEI conversion but I did do the heavy gauge dual 50amp fuse ammeter bypass and let me tell you it saved the day! Dan I can't thank you enough for suggesting this while doing my alternator swap.
As far as I can tell the VR128 went tits up while driving around with the heat blasting and the lights on and with no ammeter I had no clue. Got home and when I went to put the car in the garage I had a dead battery. To late to investigate so I left it for the morning. This morning I threw the battery on the charger and found that the fuse at the alternator side had blown, saving me from having to rewire my car or worse.....
I put in a new fuse, stuck my meter on the battery and fired it up. 18+ volts at the battery! I had the VR101 on the shelf so I stuck that in there, fired it up and "viola!" 14.2ish. Reading at the alternator output I'm getting 15. Sound about right?
Thanks again Dan. So on my list now is a voltage gauge along with the HEI and that should be it for electrical.
'60 Valiant
PostPosted: Sun Nov 29, 2015 5:31 pm
Glad to have helped (yes, this is why we put fuses at both ends!). Interesting about the dead VR-128; what brand is it, d'you know?
