| 1967 Dart 225 slant overheating issue https://slantsix.org/forum/viewtopic.php?t=58216 |
Page 2 of 2 |
| Author: | wjajr [ Wed Aug 12, 2015 5:29 am ] |
Quote: We just recently did a valve adjustment, but that wouldn't have anything to do with that would it?
Pull the valve cover, and have a look-see.
| Author: | smitty040 [ Wed Aug 12, 2015 8:42 am ] |
Fuel, air, spark.... Bought my own set of feeler gauges today as I will always need them and planning to borrow a compression gauge. Warm motor, all plugs out, and throttle open is what I've read to do when testing for compression. I'll give an update once I've tested both. |
| Author: | wjajr [ Wed Aug 12, 2015 9:00 am ] |
Quote: Bought my own set of feeler gauges today as I will always need them and planning to borrow a compression gauge.
While you're at it pick up a remote starter switch that can be operated while under hood; it connects to starter relay. When I perform compression tests I connect battery charger to battery.
| Author: | cpslntdchrg [ Wed Aug 12, 2015 8:42 pm ] |
And remember to remove air filter and have the carb butterfly wide open while testing compression. (Or remove carb). |
| Page 2 of 2 | All times are UTC-07:00 |
