BBD throttle cable?
https://slantsix.org/forum/viewtopic.php?t=58631
Page 2 of 3
Author:  matv91 [ Sat Feb 13, 2016 4:44 pm ]
http://www.rockauto.com/en/partsearch/? ... m=3820+952
Author:  matv91 [ Sat Feb 13, 2016 4:55 pm ]
My info 82 83 truck parts says 4241 226 is for one barrel. 3820 952 for two barrel. 30 plus year old info, Trust worthy unkown?
Author:  Reed [ Sat Feb 13, 2016 5:21 pm ]
Interesting. My numbers come from the 78-80 dealer parts book.
Author:  matv91 [ Sat Feb 13, 2016 5:35 pm ]
http://autoricambi-euroamerica.com/1982 ... harger.pdf Parts book link
Author:  matv91 [ Sat Feb 13, 2016 5:53 pm ]
Here where it came from http://autoricambi-euroamerica.com/
Author:  Reed [ Sat Feb 13, 2016 8:26 pm ]
http://autoricambi-euroamerica.com/1982-1983_Dodge_Plymouth_Truck_Van___Ramcharger.pdf Parts book link
:shock: :D Image
Thanks!
Author:  Rick Covalt [ Sun Feb 14, 2016 10:27 am ]
I just measured my truck from the firewall to the mounting stud of my carb is 15". Allowing for a little sag in the cable and @ 3" inside the cab and the cable for my truck should be about 19-20" OAL. Now where is it! :lol: :lol:
All the cables I see are between 26.5 and 30" long. None of them are going to work without a loop, which we are trying to avoid.
Also just for reference: From the firewall to the super six cable clamp in a straight line is 9". That means the main housing should be 10-11" long
If anyone locates one let me know.
Author:  matv91 [ Sun Feb 14, 2016 12:06 pm ]
http://www.rockauto.com/en/moreinfo.php ... 6569&jsn=4 MY aspen fire wall opening for throttle and the down angled bracket for carb are at same level, straight across from another. A short straight cable would not line up with angled bracket . Half a loop is needed ,like in the picture
Author:  Reed [ Sun Feb 14, 2016 12:21 pm ]
http://www.rockauto.com/en/moreinfo.php?pk=4216569&jsn=4 MY aspen fire wall opening for throttle and the down angled bracket for carb are at same level, straight across from another. A short straight cable would not line up with angled bracket . Half a loop is needed ,like in the picture
Aspen and Volare two barrel cables did not have a loop. I have owned several and converted several. The one barrel cable was longer than the two barrel cable.
Author:  matv91 [ Sun Feb 14, 2016 1:12 pm ]
http://i1373.photobucket.com/albums/ag3 ... zfpif6.jpg Notice the two cables in the picture. Top full loop, bottom what I call half a loop or a dip.
Author:  Rick Covalt [ Sun Feb 14, 2016 1:26 pm ]
The bottom cable in your picture is what I am trying to find for a truck. I already have a loop and what to eliminate it. I am using the original 1 barrel cable that was on my truck and I have a kind of a spiraled twist in it to get to the cable bracket.
Also just for the record, I searched through my 86 FSM for 45 minutes last night for a picture or a description with no luck.
Author:  matv91 [ Sun Feb 14, 2016 1:27 pm ]
Author:  Reed [ Sun Feb 14, 2016 1:37 pm ]
I admit I have never worked on a 1980 two barrel Aspen or Volare, but every factory 77-79 Diplomat, LeBaron, Aspen, and Volare I have ever seen or worked on did not have a loop in the throttle cable. I have converted single barrel cars to two barrel carbs and re-used the single barrel throttle cable by looping it, but the factory two barrel cable was shorter than the single barrel and did not have a loop.
I suspect that the FSM page you are posting is a 1980 only item.
Author:  matv91 [ Sun Feb 14, 2016 1:43 pm ]
83 was the last year for Bbd. I think not sure.
Author:  matv91 [ Sun Feb 14, 2016 2:07 pm ]
http://www.rockauto.com/en/moreinfo.php ... 6569&jsn=4 This link shows the mounting length, 20 inches. Cut a length of wire to 20 inches. Go from fire wall down half loop and back up to angled bracket. Might be to long or too short or just right.
Page 2 of 3 All times are UTC-07:00
