It is currently Mon Nov 16, 2026 6:47 am
Post new topic  Reply to topic  [ 20 posts ]  Go to page Previous 1 2
PostPosted: Wed Dec 16, 2015 6:30 pm
I used a dremel on the mains also,no issues.
PostPosted: Wed Dec 16, 2015 7:04 pm
On the main Bearing shells or on the Oil holes that cross through the crank?
PostPosted: Tue Dec 22, 2015 8:39 pm
bearings.
PostPosted: Tue Dec 22, 2015 10:43 pm
Site Admin
The slant cranks that I've had to scrap due to cracks, cracked at the oil passages.
My opinion on this is: a groove in the journal may invite a failure or crack local to the modification.
CJ
PostPosted: Fri Dec 25, 2015 12:23 pm
Car Model: 64 Valiant
Your right Ceej! Back in the 60's, grooving the crank was though to be high tech for the time, but even back then, it was found that it did promote crank failure and is now a taboo practice. Cranks were then cross drilled and this has become the industry standard for many OEM performance brands that offered high performance engine packages as well as by all aftermarket crank companies. On an engine with only 4 mains, you need all the surface area you can get for journal support.
