Brake Caliper Rattles on Disc Upgrade!
https://slantsix.org/forum/viewtopic.php?t=58938
Page 2 of 3
Author:  '67 Dart 270 [ Tue Jan 12, 2016 1:21 pm ]
Post subject:  rubber bands
Some folks never use them and apparently have no rattles. My only data point is that I just installed a set, used the rubber bands, and have no rattles.
b
Author:  matv91 [ Sat Jan 16, 2016 4:37 am ]
Author:  matv91 [ Sat Jan 16, 2016 6:03 am ]
Author:  matv91 [ Sat Jan 16, 2016 6:07 am ]
Author:  Danarchy [ Sat Jan 16, 2016 10:17 am ]
matv91 - Thank You! I am going to tear into the brakes this afternoon and those pages are Extremely Helpful!
Author:  '67 Dart 270 [ Mon Feb 08, 2016 12:08 pm ]
Post subject:  bolt size?
What is the bolt size and length/thread size for the bolt that holds the caliper bracket (slider type) to the spindle on these disc brakes? Mine are 11" rotors, slider style. It's a fine thread pitch I know that much, about 2-2/5" long, but does anyone have the exact specs for this bolt?
thanks so much,
Brian
Author:  '67 Dart 270 [ Mon Feb 08, 2016 12:22 pm ]
Is it 1/2-20 thread, 1 5/8" long? That sounds about right, want to confirm.
brian
Author:  SpaceFrank [ Mon Feb 08, 2016 3:07 pm ]
I can't see the threads with everything put together, but the holes in my spare M-body caliper brackets (11" rotor) are 1/2". The head on the bolts installed on my car is 3/4", which also implies a bolt diameter of 1/2". I don't recall if they were coarse (1/2-13) or fine (1/2-20), but fine seems more likely.
1-5/8" sounds about right for bolt length. My spare brackets look to be about 3/4" thick where these bolts pass through, if you take the countersink into account.
Kinda fuzzy info, but I hope that helps.
Author:  '67 Dart 270 [ Tue Feb 09, 2016 11:06 am ]
Post subject:  Thanks!
Confirmed, it is 1/2-20, 1 5/8" long, full threads (although given the thickness of the bracket, I don't think you need full threads as long as the non-threaded part is less than the bracket thickness).
b
Author:  Danarchy [ Mon Feb 15, 2016 3:08 pm ]
UPDATE: Finally got a chance to get back to my brakes! I pretty much used everyone's suggestions. Applied BrakeQuite goo on the back of the pads, added the Rubber Band things in the proper place, checked wear on the slider brackets against a Brand New Pair. No significant wear whatsoever! :D The Retaining Clips were the major problem! The ones that came with the calipers were flimsy, thin, and cheaply made. I replaced them with a slightly heavier stamped metal type that work well!
Top: Old
Bottom: New
Author:  Rob Simmons [ Tue Feb 16, 2016 6:43 am ]
Gotta love this Forum!
So,... Did it work? :D
Author:  Danarchy [ Tue Feb 16, 2016 8:06 am ]
[quote]Gotta love this Forum![/quote]
Quite Now and Stops like it never has before. :lol:
Author:  matv91 [ Mon May 07, 2018 5:38 pm ]
Post subject:  Re: 74 tsb
Author:  matv91 [ Mon May 07, 2018 5:41 pm ]
Post subject:  Re: tsb
Author:  matv91 [ Mon May 07, 2018 5:43 pm ]
Post subject:  Re: Brake Caliper Rattles on Disc Upgrade!
Page 2 of 3 All times are UTC-07:00
