Custom grind
https://slantsix.org/forum/viewtopic.php?t=59091
Page 2 of 3
Author:  Badvert65 [ Sun Feb 14, 2016 3:42 pm ]
Something to keep in mind. They literally made millions of these engines and they typically went in the lower end ($) vehicles. The slant six was the corporate, go-to, base engine. With this in mind, you can see why there would be variances. That is why you really have to measure things.
It isn't really that hard to cc a head. Look at this kit and you should be able to figure it out.
http://www.ebay.com/itm/JEGS-Performanc ... 77&vxp=mtr
You can also get inexpensive measuring calipers from places such as Harbor Freight to measure the distance from the piston (at top-dead-center) and the top of the cylinder block (deck height), as well as the thickness of the old head gasket.
You really need to know all of these things on your particular engine to know what you are starting with to plan where you go.
There really is no way around this.
Author:  sandy in BC [ Sun Feb 14, 2016 4:06 pm ]
or.... http://www.slantsix.org/forum/viewtopic ... vol+volume
Author:  Badvert65 [ Sun Feb 14, 2016 7:31 pm ]
That is funny because my wife is a nurse and I got a syringe from her to take my head cc measurements. I had pieces of Plexiglas available, that was the easy part. I only listed the Head CC kit as I wasn't certain where to get the syringe (if they didn't have any medical contacts).
Author:  emsvitil [ Sun Feb 14, 2016 8:00 pm ]
Tractor supply has syringes
You get syringes with ink refill kits
Probably on Amazon and Ebay too.
Author:  wjajr [ Tue Feb 16, 2016 6:30 am ]
Tractor Supply
Author:  225kid [ Sat Feb 20, 2016 1:20 pm ]
So i found out that i have a 55cc chamber
Author:  Joshie225 [ Sat Feb 20, 2016 7:25 pm ]
Good. Now: How far down the bore are the pistons at TDC? Stock bore size?
Author:  225kid [ Sun Feb 21, 2016 12:23 pm ]
Its .165 down the hole and 3.4 bore
Author:  Joshie225 [ Sun Feb 21, 2016 2:29 pm ]
8.22:1 with a .034" thick 3.5" bore head gasket.
Author:  225kid [ Sun Feb 21, 2016 3:12 pm ]
How much would i have to shave to get to 10.1?
Author:  ProCycle [ Sun Feb 21, 2016 3:18 pm ]
My calculator says 0.095"
You may want to split that between the head and block.
Author:  225kid [ Sun Feb 21, 2016 3:22 pm ]
Okay, ive had .040 taken off of the head already so of i take .065 of the block and .30 off the head am i going to run into a push rod clearance issue?
Author:  DusterIdiot [ Sun Feb 21, 2016 4:30 pm ]
Post subject:  Yep...
Yes, you will need pushrods from Smith Brothers, you can make a measuring fixture out of one of your old pushrods so you can lock in the length and send to them to make the correct length.
Author:  225kid [ Wed Feb 24, 2016 3:55 pm ]
Okay so im pulling the motor out some time this weekend and because im kind of on a budget could i take .095 off the block? Or would it be more logical to change the pistons to domed with valve reliefs? Im looking at a .490 lift cam with about 230ish duration. Thanks
Author:  DusterIdiot [ Wed Feb 24, 2016 6:08 pm ]
Post subject:  It's...
Stock flat tin tops are the cheapest pistons, a set of domed pistons is going to set your wallet back quite a few hundred dollars....
It's best to take some off the head and block so both mating surfaces are flat and true so the head gasket seals better...
Taking the combined cut will still require pushrods...
Page 2 of 3 All times are UTC-07:00
