| Power outputs from your Slant 6's? https://slantsix.org/forum/viewtopic.php?t=59582 |
Page 2 of 2 |
| Author: | CNC-Dude [ Wed May 04, 2016 1:59 pm ] |
I'm sure with you playing with the car before you took it to the track, have you tried to stall the converter in the driveway or in the street to test the stall and to see if it would build boost. How long does it take to get more boost built up than what you are seeing at the drag strip? |
| Author: | Rick Covalt [ Wed May 04, 2016 2:52 pm ] |
Keep up the good work Bill, and keep us posted! Anxious to hear how it works. Rick |
| Author: | Junior [ Wed May 04, 2016 3:33 pm ] |
Quote: Dart 270,
for what you spent on all of that you probably could have gotten a slightly smaller exhaust housing. or if you are running divided, a quick spool valve.
Here are the summit part numbers I ordered: NEX-20421-10 Nitrous Express system, 35-50-75-100-125-150 hp EDL-72176 Edelbrock purge system ARC-1402 time-delay 40-amp relay .1-sec. adustable to 1 full second system activator All Summit part numbers and all were shipped immediately. Not cheap, but cheaper than the alternative (new converter or new turbo.) Hope this helps... Bill |
| Author: | Joshie225 [ Wed May 04, 2016 3:54 pm ] |
Turbine housings aren't that expensive. http://www.atpturbo.com/mm5/merchant.mv ... y_Code=GTH |
| Author: | billdedman [ Wed May 04, 2016 10:45 pm ] |
Quote: Keep up the good work Bill, and keep us posted! Anxious to hear how it works.
Thanks, Rick! The nitrous equipment order arrived today (Wednesday) and will be installed late this week, I hope. It seemed simple (on paper,) but, that box is HEAVY... so, I'm wondering why... Rick Guess I'll find out tomorrow... lol! Bill |
| Author: | billdedman [ Wed May 04, 2016 11:04 pm ] |
Quote: Turbine housings aren't that expensive.
Thanks for the excellent link, Josh! http://www.atpturbo.com/mm5/merchant.mv ... y_Code=GTH My problem is that I am not aware of the way this turbo mechanism goes together... I need a crash-course in the vagaries of impeller wheel/housing engineering as regards sizing and appropriate fitment of the various dimensions used to make this apparatus work like I want it to. I have not been educated in sizing of turbos at all, and am wondering, for example, to get a faster-spooling turbo, is it just a matter of downaizing the scroll-housing, or is it necessary to also change-out the impeller for a smaller one? I don't even know enough about how this system works, to talk intelligently about it. I had asked a ball-park figure from "The G-Pop Shop," the only turbo shop I have talked to about this, and he was pretty sure it would cost me about $750.00 for what I wanted, but, that was for a whole new turbo like Ryan's. If I could have gotten what I wanted by just changing the exhaust housing, ahould ne not have suggested that? I just am really ignorant about what is possible with what I have... Bill |
| Author: | billdedman [ Wed May 04, 2016 11:14 pm ] |
Quote: Quote: Dart 270,
for what you spent on all of that you probably could have gotten a slightly smaller exhaust housing. or if you are running divided, a quick spool valve.Here are the summit part numbers I ordered: NEX-20421-10 Nitrous Express system, 35-50-75-100-125-150 hp EDL-72176 Edelbrock purge system ARC-1402 time-delay 40-amp relay .1-sec. adustable to 1 full second system activator All Summit part numbers and all were shipped immediately. Not cheap, but cheaper than the alternative (new converter or new turbo.) Hope this helps... Bill I hope it WILL work... lol! I'll let everybody know.... Bill |
| Author: | billdedman [ Wed May 04, 2016 11:21 pm ] |
Quote: How much boost does it have when you leave the starting line?
Only 3-4 pounds... not nearly enough. That's at 3,000 rpm.
| Author: | billdedman [ Wed May 04, 2016 11:28 pm ] |
Quote: I'm sure with you playing with the car before you took it to the track, have you tried to stall the converter in the driveway or in the street to test the stall and to see if it would build boost. How long does it take to get more boost built up than what you are seeing at the drag strip?
It's had ample stall-start testing done in a variety of venues and has proven, conclusively, that the turbo and the converter are enough of a mismatch that something had to be done... Now, we'll see if what I did, works. I'm hoping... Bill |
| Author: | Junior [ Thu May 05, 2016 4:33 pm ] |
you are running a turbonetics right? from what i hear they have excellent customer service. have the information for your turbo in front of you and give them a call and explain what you are looking to do. they should be able to set you up with a smaller housing that will fit your wheels. |
| Author: | billdedman [ Thu May 05, 2016 10:11 pm ] |
Quote: you are running a turbonetics right? from what i hear they have excellent customer service. have the information for your turbo in front of you and give them a call and explain what you are looking to do. they should be able to set you up with a smaller housing that will fit your wheels.
Yes, it's a four-bolt flange, 66mm Turbonetics.I have too much on my plate right now, but after I get this nitrous spool system sorted out, I'll definitely call them! Thanks for the good advice! Bill |
| Page 2 of 2 | All times are UTC-07:00 |
