| checking pinion angle https://slantsix.org/forum/viewtopic.php?t=59824 |
Page 2 of 2 |
| Author: | akbmotorsports [ Mon Jul 18, 2016 5:42 pm ] |
| Post subject: | angle |
DT, when i set up the truck, with all 4 wheels on ground, I measured at the trans shaft and diff yoke as you have, then installed driveshaft and measured its angle. trans at 4 degrees(down), diff at 4 degrees(up), driveshaft measured at 6 degrees, resulting in 2 degree u joint operating angle. rolls nice and smooth. andy. |
| Page 2 of 2 | All times are UTC-07:00 |
