It is currently Mon Nov 16, 2026 10:44 am
PostPosted: Tue Jul 26, 2016 7:10 am
GTS 225:
And just where did you get that info?
8.75 rears from an A-body are 5-on-4" pattern, and B-body rears are 5-on-4.5" pattern.
Rick:
You could also look for a 8 1/4 out of a later A body and that would be a bolt in. Of course you need to shorten the driveline. You may want to get a plan together for doing the big bolt disc brake swap up front. It is a huge upgrade safety wise and then the 8.8 or an 8 1/4" would have the 4.5" bolt circle to match the front
PostPosted: Tue Jul 26, 2016 7:56 am
I made a mistake
A body 8 3/4 are 5x4
PostPosted: Wed Jul 27, 2016 3:20 pm
You may want to do a little research and check into a B body 8 3/4" rear if you want an 8 3/4. They are usually quite a bit less than an A-body one and with the right offset wheels should work fine.Plus you get bigger brakes and 4.5" bolt pattern
I also have a friend who installed a 8.8 out of a Mustang in an A-body, with the right offset wheels. He didn't have to cut any axles or anything.Just moved the spring perches. Plus if it is out of a GT it should already have the posi in it.
Just some more options.
