It is currently Mon Nov 23, 2026 6:39 pm
Post new topic  Reply to topic  [ 70 posts ]  Go to page Previous 1 2 3 4 5 Next
PostPosted: Mon Jun 16, 2003 6:25 am
The problems fitting the HP to the head I can deal with. The internal casting flaws I can't.
Cecil
PostPosted: Mon Jun 16, 2003 10:24 am
Cecil
It is disappointing to hear that the latest batch of Clifford Hyper-Pak castings are not as nice as the ones in the past.
The clearance to the washers and to the exhaust manifold(s) has always been an issue, that is extra thick aluminum wall left behind from the first big port “Fat-Paks” manifold that were cast. When the port size was reduced we decided to leave the extra wall thickness for strength and for optional porting, this means some fitting and grinding is required to get the needed clearance. There is plenty of wall thickness in those areas so have at it. I did all this extra "fit-up grinding" work when I sold that manifold but it sounds like Clifford is not doing a trial fit-up or any finish work.
The “V” shaped runner wall is sad to hear about, that is from poor sand core preparation. It is so easy to get all those runner ends square and nice with a file and a few minutes “hand working” each sand core before they go into the mold. Good sand core prep is the key to a nice casting.
Looks like I will need to call the Clifford people to “walk them through" these extra steps they seem to be skipping. I had it all documented and had “trained” Jack Clifford on how to run this manifold when all the tooling was delivered to them. Now that Jack has passed-on, looks like I need to trained them again.
PostPosted: Mon Jun 16, 2003 11:41 am
My model came as shown in the pics, two sets of holes, and there's no flash in the runners. I got mine off e-bay a year or so back, so I'm not sure what year it was 'born' to the world.
thanks for the affirmation on the 'grind it'. I'm going to grab a gasket to check/ match things up, mock it up again and magic marker/dye everything that needs to be 'massaged'...then go to town....
thanks Doc!
:D
PostPosted: Mon Jun 16, 2003 1:47 pm
When I ordered mine (still haven't seen it yet - even though it was "in stock") Clifford told me all the new HPaks have the Clifford adapter pattern instead of the Holley 4 bbl pattern. Which means you need to choose one of Clifford adapters for the carb you want to run. Guess that assures them volume on their adapters - But on the good side you are only an adapter away from the next setup (2 bbl, throttle body EFI, etc)
PostPosted: Mon Jun 16, 2003 2:18 pm
Carb. adaptors are a problem on the Hyper-Pak just because of the limited hood clearance this manifold has.
Again, this sounds like some more cost cutting on Clifford's end, the carb flange on the Hyper-Pak casting is big enough to take many of the more common bolt patterns so you may want to drill-in the one you need and avoid the adaptor.
PostPosted: Mon Jun 16, 2003 11:24 pm
I had to get the carb adapter with mine. I haven't checked out the casting on the runners to closely but when I put the carb adapter on the manifold the manifold actually protrudes about 1/4 inch into the throttle bore are of the carb adapter. I am either going to have to drill and tap new holes directly on the manifold or do a bunch of grinding to use the carb adapter. :x :evil: The cabr adapter does add alot of height so I will probably just put in some new holes. Grrrr.
Reed
PostPosted: Tue Jun 17, 2003 9:18 am
Reed (and others with undrilled H-Paks)
I still the carb mount hole drilling jig I made for this project. (Clifford did not want it. :? ) I can loan it out.
The jig is a thick plate that fits into the plenum opening and it has the carb mounting holes pre-drilled in the jig plate. You clamp the jig down to the manifold and use your hand drill and just follow the holes in the plate, it works pretty well.
I have the small and the large Holley square pattern layed-out in the jig.
PostPosted: Wed Jun 18, 2003 4:12 pm
Slant Cecil,your intake casting sounds just like mine(I received it two weeks ago) and I thought it was suppose to be like that,Im, glad you brought this to my attention.As for the adapter ,I just used a 1 inch aluminum spacer to drill the holes for the Holley pattern and it looks as though ill have to use the spacer to clear my carb linkage(Im not worried about hood clearance as ill fabricate a scoop or maybe a offset shaker deal).
Doc, im looking forward to your idea of how to make the h-p work in a low rpm situation as I plan on using this in a 1500 to 5000 rpm range.Right now im researching cams for this application.
Also,am I correct in thinking that for the street I will need to maintain a healthy vacumm signal to pull the fuel through those long runners at idle?
I think that this thread is far from being over as the number of h-p intakes seems to growing.
Mark
Ive got a slanted attitude and a heavy right foot.
PostPosted: Wed Jun 18, 2003 5:08 pm
Mark, I didn't pull mine out of the box for almost two weeks. I'm not convinced pieces of the divider wall won't break off in the future and go thru the motor. I called Clifford, after telling them the problem, they just sat on the phone without any response. I thought they may have an answer. I finally had to tell them it was unacceptable, now I have to call back when 'Tammy' is in to get authorization for return. If others are like it, I don't won't to get another 'blem' as a replacement, freight 2 ways is too much. I'm asking for a refund or credit on headers. Something tells me Clifford is not going to be return friendly.
Cecil
PostPosted: Wed Jun 18, 2003 6:18 pm
Anyone talking to Clifford is welcome to use my name (Doug Dutra) as a resource to help fix the problems with the Hyper-Pak manifold.
Since there is a whole new group running Clifford these days, I need to "remake" a relationship with them so some "name dropping" could help me do this.
PostPosted: Thu Jun 19, 2003 6:56 am
Before these manifolds start getting sent back to Clifford, are there any casting marks on them that might identify these from coming from a specific batch?
I would hate to pick one of these up off of ebay (or from Clifford) in the next few years, only to find out that I received one of these poorly cast ones.
Also, can anyone post some pictures of the problems?
John Killin
PostPosted: Thu Jun 19, 2003 8:35 am
John, I'll Email ya some pics. These are the lastest batch. I ordered mine 3-8-03 and was told they were in stock. 3 weeks later I called to find out why I hadn't received it, was told they were out of stock and running a new batch. Another thing I asked when I ordered, was if a Holley would bolt on, was told yes. Of course, that's only with an adapter they failed to mention. When I called Clifford Tuesday about the problems, I was told the holes were not drilled so a 2 barrel could be used. Either way an adapter is needed. I thought someone wanting a HP intake isn't thinking too much of a 2 barrel, OK, I was, but I'd still prefer the 4 barrel holes be drilled.
Cecil
PostPosted: Thu Jun 19, 2003 2:23 pm
I'm posting links and Cecil's explanation of the photos of his clifford hyperpack.
http://pages.moparpages.com/killin5/Cli ... %201-4.jpg
http://pages.moparpages.com/killin5/Cli ... %204-6.jpg
There are 5 dividing walls for the 6 runners. The center one is not too bad, I could live with it if they were all like it. Each shot shows the center with 2 either side of it. See how the end is not straight up and down? It's > shaped. One looks as if a piece has already broken off.
http://pages.moparpages.com/killin5/Cli ... er%205.jpg
Another pic is #5 runner, something must have fallen in the core when cast, looks like an imprint of someones gum!
http://pages.moparpages.com/killin5/Cli ... Flange.jpg
The last pic shows the carb flange not drilled for a Carter or Holley carb, only for their adapter. They took a shortcut to save money or this is their way to sell adapters.
PostPosted: Thu Jun 19, 2003 4:24 pm
none of the links or pictures work :(
PostPosted: Fri Jun 20, 2003 11:17 am
Can you see it now?
