| Super 6 intake and exhaust manifold question https://slantsix.org/forum/viewtopic.php?t=60090 |
Page 2 of 2 |
| Author: | shadango [ Sun Sep 25, 2016 9:15 am ] |
NOT SO FAST!!! WOOHOO! Decided to grab the end of the bolt that was sticking through with vice grips and keep heating and soaking with blaster/blu torch. Eventually -- MOVEMENT! Was a pain in the doopah but they both eventually came out. |
| Author: | shadango [ Sun Sep 25, 2016 9:17 am ] |
Quote: Cut the bolts, drill them out and use long bolts as replacements. Don't bother to tap the exhaust manifold. Use a low strength bolts. If you ever take it apart again, you can just break the bolts if they are corroded. Makes disassembly a breeze.
Now that I have the bolts out and the original threads are still in tact, would it be a fools errand to drill out the threads and use the low strength bolts at this point?I question why they even threaded the exhaust manifold AND used nuts on the end?? |
| Author: | SlantSixDan [ Sun Sep 25, 2016 9:46 am ] |
Quote: Now that I have the bolts out and the original threads are still in tact, would it be a fools errand to drill out the threads and use the low strength bolts at this point?
Yes. Use appropriate (high-strength) bolts that will withstand the thermal cycling, with anti-seize compound on the threads and brass nuts as needed. Disassembly in the (hopefully distant) future will be a cinch.Quote: I question why they even threaded the exhaust manifold AND used nuts on the end??
The nuts were used to space the throttle/kickdown bracket appropriately from the manifold.
| Author: | shadango [ Sun Sep 25, 2016 9:54 am ] |
Quote: Quote: Now that I have the bolts out and the original threads are still in tact, would it be a fools errand to drill out the threads and use the low strength bolts at this point?
Yes. Use appropriate (high-strength) bolts that will withstand the thermal cycling.Quote: I question why they even threaded the exhaust manifold AND used nuts on the end??
The nuts were used to space the throttle/kickdown bracket appropriately from the manifold.Ok so like a grade 8 then? Hoping these are common size/length bolts available at the hardware store! I am doing a dry run of the "new" to us 2 bbl manifold and the original exhaust manifold......and thinking (overthinking?).... We want to paint the exhaust and intake but I know that once the two are mated they should be surfaced together right? And not diassembled after that, correct? I hate to paint these and then have a shop manhandle to surface then and mess up the paint....but if we have them surfaced together and then we pull apart to paint them, we may have a bugger of a time re-mating them..... |
| Author: | shadango [ Mon Sep 26, 2016 11:24 am ] |
Anyone know the size and length these bolts bolts need to be? I meant to measure them so I can stop after work today and guess what I forgot to do...LOL |
| Author: | shadango [ Tue Sep 27, 2016 8:02 am ] |
SO the bolts are 3.5" long 5/16"- 18 bolts. Someone in another thread said they are 4" long...but my originals are 3.5". (1980 slant 6) Cant locate any grade 5 or 8 bolts with enough thread so far...found a 4" long bolt that works, but not sure the basic steel will be tough enough? I assume trying to use a die and cut the threads longer on a grade 8 would be not very doable by hand.... SO I just ordered 5/16"18 grade 5 yellow zinc plated 3.5" bolts and nuts and washers from fastenall..... |
| Author: | SlantSixDan [ Tue Sep 27, 2016 10:16 am ] |
I would use grade-8, but grade-5 is probably good enough. I don't recall having much trouble getting them, but the last time I needed to was quite a few years ago. |
| Author: | shadango [ Tue Sep 27, 2016 12:11 pm ] |
Quote: I would use grade-8, but grade-5 is probably good enough. I don't recall having much trouble getting them, but the last time I needed to was quite a few years ago.
Its the ALL THREAD that is the problem. But my local fastenall can get them for me.....hopefully will have them thursday.
| Author: | imanexcellentdriver [ Sat Oct 08, 2016 10:08 pm ] |
If anyone cares, here's my cobbled together linkage I shot for u/gdizzle: ![]() ![]() ![]()
| Page 2 of 2 | All times are UTC-08:00 |
