| Alternative to the "remflex" heat riser gasket?? https://slantsix.org/forum/viewtopic.php?t=60225 |
Page 2 of 2 |
| Author: | SlantSixDan [ Tue Sep 27, 2016 5:45 pm ] |
It wouldn't, because AFAIK your options in hotbox (heat riser) gaskets are stamped metal or Remflex, end of list. I could be wrong. If I'm wrong, I'll be glad to learn—and then I'll keep using and recommending Remflex. |
| Author: | Rick Covalt [ Tue Sep 27, 2016 6:45 pm ] |
I'm sorry, two different things being discussed in the thread. I was speaking of the intake/exhaust gasket not the one between the manifolds. Now Reed's comment about the metal one makes more sense! Didn't mean to gum up the works! |
| Author: | shadango [ Wed Oct 05, 2016 6:57 am ] |
Quote: I'm sorry, two different things being discussed in the thread. I was speaking of the intake/exhaust gasket not the one between the manifolds. Now Reed's comment about the metal one makes more sense!
Rick took care of me for the Remflex heat riser gasket (payment coming soon !!) and Brian hooked me up with the Thermoseal gasket...gonna try that and see how it works out. I like reusable when its possible. And the cost was pretty good too <wink>Didn't mean to gum up the works! I will report back once we get the red baron back up and running....install date keeps getting pushed due to Damper Doctors messing up my damper, then multiple subsequent shipments of it. Crossing my fingers we get it soon. |
| Author: | 75valiant [ Thu Oct 06, 2016 3:51 pm ] |
hope you have good luck. i just bought my first remflex, for my ford pickup 300. i finally figured out why ford went to two cast iron manifolds when they fuel injected the 300; the log manifold is too long and they ALL warp! they didn't even use a gasket at the factory. i was pleased to be informed by the folks at remflex that their product is not only guaranteed for 6 months, but that they will replace it EVEN IF you damage it during installation! they are apparently big on customer satisfaction. on the other hand, i understand being a poor boy. it sucks when you have to make compromises that you otherwise wouldn't. like i said, good luck! |
| Page 2 of 2 | All times are UTC-07:00 |
