| NEW Blower for Slantys from Torqstorm! https://slantsix.org/forum/viewtopic.php?t=60682 |
Page 2 of 4 |
| Author: | Rick Covalt [ Wed Aug 09, 2017 12:47 pm ] |
Quote: Approximate cost? $2800 I know someone who has one in his possession. It is yet to be seen if the unit ever makes it onto a running car. From what I have seen (Just a quick look) it looked really decent. |
| Author: | Leaning Dusty [ Sat Aug 12, 2017 12:26 pm ] |
Holy moly! I was originally thinking NA then going to turbo a bit later, but now I may need to reconsider some NA static/compression ratios and consider a bolt-on supercharger. Would this unit still work with A/C? I imagine the blower pulley would be going where the stock compressor would go... that may be my only limiting factor. Relocating the A/C compressor and alternator may be an option, though. I've seen some interesting dyno videos of a supercharged Aussiespeed car, which made very little power (still substantially more than stock), but made over 400 lb/ft of torque at the wheels. It was likely a limitation of the head or the bottom-end build that kept the motor from spinning fast enough to make some significant top-end horsepower, but wondering if this is going to be a similar design. Either way, I'll be watching! |
| Author: | Scampin around [ Sun Nov 19, 2017 9:46 am ] |
| Post subject: | Re: NEW Blower for Slantys from Torqstorm! |
Any updates? |
| Author: | EC_CO [ Thu Nov 30, 2017 6:25 am ] |
I'm interested in any updates too. http://www.torqstorm.com/supercharger_kit_slant_6.html |
| Author: | Dart270 [ Thu Nov 30, 2017 7:22 am ] |
Rick, Maybe my Project V can be a test mule for that kit you have laid eyes on??? In any case, I am thinking this might be a nice upgrade for that motor/car... Lou |
| Author: | Rick Covalt [ Thu Nov 30, 2017 10:44 am ] |
Ryan has one that he is going to put on his Dart once the restoration is complete. Probably mid year 2018 I would guess. Ryan has not posted about his Dart, but I have put eyes on it a couple times. It should be a sweet ride. 72 swinger Drag / Road race car. Front coil over/rack & pinion steering, rear 4 link, mini tubbed, and all the body stiffening you can think of. Power train will be a fuel injected Slant 6, blower motor, backed up by a Passon 5 speed with new 4.56 rear gear and huge tires. Body work is nearly done and it should be ready for paint sometime soon I would guess. |
| Author: | Dart270 [ Thu Nov 30, 2017 10:58 am ] |
Wow, cool! I better hurry up and spruce up the turbo car. I have many of those things on my list for this winter... I am still thinking about the TorqStorm and looking into that for the V. Lou |
| Author: | slantzilla [ Sun Dec 03, 2017 8:18 pm ] |
Lou, how much hp would 9 psi support? |
| Author: | Dart270 [ Mon Dec 04, 2017 3:14 am ] |
Hi Dennis, Based my turbo car testing, I'd say somewhere around 275-350 RWHP with the right overall combo and buildup. I am not sure how cam and things like that will affect things differently, but my car has made around 275 RWHP on 9 psi. That is with an old shortblock (170k miles), 8.6:1 SCR, Jeffrey head, MP 244 cam, and pretty conservative (pump gas and street friendly) timing and mixture settings. My wheels are turning as well... Lou |
| Author: | slantzilla [ Mon Dec 04, 2017 8:09 am ] |
Quote: My wheels are turning as well...
That might just be enough to put a 2700# Valiant into Super Pro without breaking anything.... Lou |
| Author: | Jester [ Sat Jul 28, 2018 1:48 pm ] |
Thinking of buying one of these and slapping it on a stock supersix, then drive it until she blows up. Would it work on a stock slant with 2bbl carb? and add what, like 40hp? The holy $#!+ factor when popping the hood would be worth the $$$... |
| Author: | Jester [ Sat Jul 28, 2018 3:45 pm ] |
I suppose you'd need a 4 bbl intake manifold and a blow-thru carb... After conversion to Canadian $$$, it would be cheaper to convert to a V8 using a donor car. And a crate motor. Hmm... |
| Author: | Reed [ Sat Jul 28, 2018 4:59 pm ] |
$2800 and no AC provision means I am not interested in one of these. A turbo lets you keep all stock accessories. |
| Author: | Jester [ Mon Jul 30, 2018 12:12 am ] |
I hear ya, it's freaking hot this Summer. A supercharger is definitely on my wish list though, along with a million other things... |
| Author: | Dart270 [ Tue Jul 31, 2018 2:56 am ] |
AC is not for hot rods. John Milner would never had allowed it. Lou |
| Page 2 of 4 | All times are UTC-07:00 |
