| 1964 170 crank, in a 1973 198 motor https://slantsix.org/forum/viewtopic.php?t=60923 |
Page 2 of 3 |
| Author: | SlantSteve [ Sat Mar 25, 2017 4:41 am ] |
The Australian engines had a "Super 225" decal on an unsilenced filter and 1bbl carb...not sure what was super about it ! http://www.valiant.org/valiant/engines.html The above link is an Aussie slant. The 2bbl engines also had an unsilenced filter on some models from memory,other had a snorkel . |
| Author: | SlantSixDan [ Sat Mar 25, 2017 10:24 am ] |
No, sir. The Australian air cleaners you're talking about are silenced items, both the 1bbl and the 2bbl versions. Silenced/unsilenced is not a matter of with/without snorkel. (The air cleaner used on the 2bbl 225 in Australia did not have a snorkel. A snorkel was added to the 1bbl air cleaner for the '67 VE model. All of these were silenced air cleaners.) |
| Author: | SlantSteve [ Sat Mar 25, 2017 2:34 pm ] |
Oh reallly? I always thought the snorkel was the deciding factor...for my education what is the deciding factor that makes them silenced? Just a shroud around the filter? I don't recall the 1bbl VE filters but I do remember the 2bbl having the shallow non snorkel set up and the auto choke with the hot air pipes to the bi metal spring mounted in the carb.Thanks |
| Author: | SlantSixDan [ Sat Mar 25, 2017 3:31 pm ] |
Quote: Oh reallly? I always thought the snorkel was the deciding factor...for my education what is the deciding factor that makes them silenced?
The most obvious indicator is whether—from some angle—you could get a big, clear view of the filter with the air cleaner assembled. An unsilenced air cleaner is "yes", and a silenced one is "no". The silenced air cleaners have a small gap between the inner diameter of the lid and the outer diameter of the base; see here. Unsilenced air cleaners have a big gap in this location, or just a partial splash guard (like the '62-only 170 air cleaner shown here or those aftermarket open-element "performance" air cleaners).You can make an unsilenced air cleaner by using the base and bail from the 9" 1bbl air cleaner and the lid from the 11" 1bbl unit. That's the setup I was too busy listening to the roar from when I got stopped by a traffic cop for the very first time -- a lot of years ago on my way to high school. |
| Author: | SlantSteve [ Sat Mar 25, 2017 4:24 pm ] |
Got it...thanks Dan |
| Author: | Killer6 [ Sun Mar 26, 2017 12:19 pm ] |
Quote: OK one more question. the difference between a 198 snd the super six are the connecting rods 7.005 for the 198. 6.7 for the 225. Top Dead Center is .300 before top of black or is the piston pin on the super six move down to offset the difference ? So they are both at the top of the block ??? Thanks again Dave
Hey Yaz79, welcome to the forum! Just curious why You want to do this. What are the plans for the mill, racing,boost, etc.? You are putting the min. amount of cubes in the heaviest block, and the rods will have to be very long to achieve a decent compression ratio, and long rods have to be that much stronger/stiffer for the same applied pressure. Seems counter- productive unless You have a specific reason. |
| Author: | Doctor Dodge [ Mon Mar 27, 2017 11:13 am ] |
Quote: You would need 7.2" rods to get a stock piston to the stock 225 piston-deck ht (0.5" lower piston at TDC with 1" smaller stroke than 225 in a 225 block). 7.35" would be a better rod length to get you close to zero deck. To use a shorter piston, 7.5-7.7" rods would work well...
I used 7.875 centre to centre rods and really short pistons when I did this...Lou ( I installed a 170 crank into a 225 Aluminium Block ) As to why??? - How does a 2.52 rod ratio "feel" ? - I always wanted a Aluminium Block 170 SL6 - Some things I do.... because I can. DD |
| Author: | Greg Ondayko [ Mon Mar 27, 2017 2:34 pm ] |
Where would one source such a long rod for this type of expiriment doc? Greg |
| Author: | Dart270 [ Tue Mar 28, 2017 11:40 am ] |
Molnar said he would make them (formerly of K1). Lou |
| Author: | Doctor Dodge [ Tue Mar 28, 2017 3:11 pm ] |
Quote: Where would one source such a long rod for this type of expiriment doc?
The ones I used were out of an old Chrysler flat head six.Greg They needed a lot of reworking but I got them to fit. DD |
| Author: | Killer6 [ Fri Mar 31, 2017 8:53 pm ] |
Quote: Quote: The RG (198/225) block is an inch taller than the LG (170) block,
This is a common misconception, but not correct. Yes the 225 has a one inch longer stroke, then the 170, but the deck is actually more then an inch higher. Don't have the exact number handy, but somewhere about 1.5 to 1.625 taller. Just tried to measure them, but had eye surgery, yesterday, and can't read the numbers any closer.up with the difference needed to maintain the compression. It worked out to about 1.700" taller!! I went out and(very imprecisely) measured from the corner of the head dr. rear to the block casting in line w/the bell- housing bolt, both 170 then the 225 in the coupe, damn near 1.680"!! Funny, the Racing manual lists the deck height as 9.68" for the 170, & 10.68" for the 225/198!!! They list the rods at 5.707"(170), 6.699" (225), & 7.006"(198), so they got part of it right. But even some quick math in Your head tells you that deck height can't be right!!! Edit; The 170 is from a '62 Valiant, the 225 is from My '64GT. both were checked from the underside of the gasket. |
| Author: | Killer6 [ Fri Mar 31, 2017 9:01 pm ] |
I also happened to be looking up the OE compression ratios in a couple of different sources, and low & behold, the footnote that the '64 Darts had 8.4:1 squeeze vs. the standard 8.2:1 on the 225, 8.5:1 on the 170. Did Mopar deck the Dart an extra .020" ala the Shelby 2.2's??? |
| Author: | SlantSixDan [ Fri Mar 31, 2017 9:16 pm ] |
Quote: Funny, the Racing manual lists the deck height as 9.68" for the 170, & 10.68" for the 225/198!
Yeah, there are a lot of "funny" things (i.e., wrong facts) in that book.The ~1.7" deck height difference explains how come the water pump to cylinder head coolant bypass hose looks more than 1" longer on an RG engine than on an LG. |
| Author: | SlantSixDan [ Fri Mar 31, 2017 9:17 pm ] |
Quote: Quote: Funny, the Racing manual lists the deck height as 9.68" for the 170, & 10.68" for the 225/198!
Yeah, there are a lot of "funny" things (i.e., wrong facts) in that book.The ~1.7" deck height difference explains how come the water pump to cylinder head coolant bypass hose looks more than 1" longer on an RG engine than on an LG. Quote: I also happened to be looking up the OE compression ratios in a couple
No. The nominal compression ratio moved around a little, year by year, between 8.2 and 8.5. It was not different in Darts than in Valiants, Coronets, Belvederes, D-100 pickups, A-100 vans, etc.
| Author: | Killer6 [ Fri Mar 31, 2017 9:25 pm ] |
Quote: Quote: Quote: Funny, the Racing manual lists the deck height as 9.68" for the 170, & 10.68" for the 225/198!
Yeah, there are a lot of "funny" things (i.e., wrong facts) in that book.The ~1.7" deck height difference explains how come the water pump to cylinder head coolant bypass hose looks more than 1" longer on an RG engine than on an LG. No. The nominal compression ratio moved around a little, year by year, between 8.2 and 8.5. It was not different in Darts than in Valiants, Coronets, Belvederes, D-100 pickups, A-100 vans, etc. to just "put in there". As soon as it dries out some tomorrow, I have a 170 that is from a '64 dart 4dr, guess I'll take a measurement & see. |
| Page 2 of 3 | All times are UTC-07:00 |
