It is currently Sun May 24, 2026 7:43 am
Post new topic  Reply to topic  [ 16 posts ]  Go to page Previous 1 2
PostPosted: Wed Dec 13, 2017 5:24 pm
Car Model: 1982 Dodge D150 Slant six 4 speed
Thanks Dan?
Yep. If the crank matches you have the following options to make this work:
1) swap in a 1968-1976 forged crank (You can swap the 1965 crank as a core after you order a 1974 Forged Crank kit for the rebuild...and will come with bearings too...)
2) custom bushing to mount the 1982 flywheel to the crank and center it properly
3) 1963-1967 small crank hub 122 tooth flywheel to use on it
Also what does the crank have to match? The rebuild kit? I’m not real savvy on building motors but I’m ready to learn. That’s the only thing left in “my” books to learn how to do
