HEI conversion
https://slantsix.org/forum/viewtopic.php?t=61778
Page 2 of 2
Author:  Joshie225 [ Tue Jan 02, 2018 3:38 pm ]
Post subject:  Re: HEI conversion
Starts and then dies immediately? Where does the HEI module and coil get their battery voltage?
Author:  Magnumforce1987 [ Tue Jan 02, 2018 4:34 pm ]
They are getting juice from a single pole single pole relay which is being fed from the large alternator terminal. Switched source to operate the coil.
Author:  afastcuda1970 [ Tue Jan 02, 2018 4:49 pm ]
Where is the switched 12v source from?
Author:  Magnumforce1987 [ Tue Jan 02, 2018 5:12 pm ]
From the ignition switch, I jumpered off the terminals that used to go into the ballast resistor (which it's now bypassed). As soon as I turn the switch, the relay closes.
Author:  afastcuda1970 [ Tue Jan 02, 2018 6:35 pm ]
Did you try swapping the two wires that go from the module to the distributor?
Author:  Magnumforce1987 [ Tue Jan 02, 2018 6:45 pm ]
Yes sir, spark isn't any better.
Author:  SlantSixDan [ Tue Jan 02, 2018 11:37 pm ]
Are you 100% sure the coil's primary (small) wires are the right way round? Wrong way round = engine will run but not very well and poor-quality spark.
Author:  Magnumforce1987 [ Wed Jan 03, 2018 10:19 am ]
Yeah, there's + and - symbols on the coils pigtail port that I hooked on to, 12v from relay to coil and - to module.
Author:  Magnumforce1987 [ Thu Jan 04, 2018 8:53 pm ]
Fixed!!! All this time it was a bad coil, oredered a new coil, now I got slight orange/ strong blue and white spark. What a relief! Thank you all so much for hard work and dedication for your fellow slant6'ers and country!!!
Author:  Dart270 [ Fri Jan 05, 2018 6:21 am ]
Congrats! Nice to have that settled.
Author:  Rick Covalt [ Sat Jan 06, 2018 4:28 am ]
Now you did go back and apologize to your lowly HEI module, right? :D :D We wouldn't want his feelings to be hurt! :D :D
Good to know the fix, congratulations!
Page 2 of 2 All times are UTC-07:00
