| Once again oil pump gear damage? No it was not. https://slantsix.org/forum/viewtopic.php?t=62134 |
Page 2 of 2 |
| Author: | lgu32 [ Tue Apr 17, 2018 9:48 pm ] |
| Post subject: | Re: Once again oil pump gear damage? No it was not. |
Engine is now out of car and opened. Oil pump gear still in order. However it is pretty worn for kilometers (miles) it has seen. Will take pistons and crank off and clean the block as there is cast iron pieces everywhere. I also will try add extra feed for this gear as Doug has recommended. For conversation "a six bolt oil pump" is required. Is those pumps available somewhere Parts seen at rockauto look all the same 5 bolt configuration. |
| Author: | DusterIdiot [ Wed Apr 18, 2018 5:57 am ] |
Quote: Is those pumps available somewhere
OCPNW maybe for NOS if they have one in stock, or Junkyard for used OEM pump.Some models of the 5 bolt pumps just need the sixth hole drilled to make into a 6 bolt pump. |
| Author: | csheehy [ Thu Apr 26, 2018 5:43 am ] |
Give https://www.partsvoice.com/partsearch a try. I believe you're looking for 2463382TIP: You can input any series of numbers into the Zip Code field - likely needs to be 7 or more as US zips are seven digits long :) Good luck! -Chris |
| Author: | Dart270 [ Fri Apr 27, 2018 6:07 am ] |
Why not use the Dutra pump? I believe you can leave out the 6th bolt and seal up any small areas that do not overlap on the gasket with silicone. Lou |
| Author: | 69a100 [ Fri Apr 27, 2018 9:03 am ] |
| Post subject: | Re: Once again oil pump gear damage |
Quote: In the past the gear failure indicated just from oil pressure light. Now came "big bang" and then car was silent.
From what you say here, I'm surprised you didn't do more damage buzzin this up to 6K RPM.
I had approximately 6000rpm on it when this happened. |
| Author: | lgu32 [ Sun Apr 29, 2018 1:16 am ] |
Quote: Quote: In the past the gear failure indicated just from oil pressure light. Now came "big bang" and then car was silent.
From what you say here, I'm surprised you didn't do more damage buzzin this up to 6K RPM.I had approximately 6000rpm on it when this happened. This has been every this and then between 5-6000 rpm. I have 205/60R14 tires and 4.10 gears so highways I have use RPM's when passing. Shift point is usually at 5000 and usually I have 5300-5500 at 1/4 mile end. I have just made new plan. Next setup will have more cam - Hughes 216/220 degrees sound fine as I had plenty of compression pressure to loose (200PSI with Mopar Performance 268 cam). I will also change converter to smaller diameter. ... I dont tell you this has had same 0.06" O.S. cast pistons and still alive... I have got no reply to my emails from recommended NOS parts company. |
| Author: | lgu32 [ Tue May 08, 2018 11:02 pm ] |
Quote: Quote: Is those pumps available somewhere
Give https://www.partsvoice.com/partsearch a try. I believe you're looking for 2463382TIP: You can input any series of numbers into the Zip Code field - likely needs to be 7 or more as US zips are seven digits long Good luck! -Chris Oil pump Body Casting # 2121678 Oil Pump Cover Casting # 2463986 Do you think I am getting correct one by buying this? |
| Page 2 of 2 | All times are UTC-07:00 |
