| Molasses soak as a derust agent https://slantsix.org/forum/viewtopic.php?t=62272 |
Page 2 of 2 |
| Author: | coconuteater64 [ Fri May 04, 2018 4:40 pm ] |
| Post subject: | Re: Molasses soak as a derust agent |
Mixes easier than shampoo! I just pour it into hot water and stir it with a stick. Don't dump it in, just pour. |
| Author: | slantzilla [ Wed May 09, 2018 7:16 pm ] |
Good stuff John. |
| Author: | Dart270 [ Thu May 10, 2018 6:03 am ] |
So nice! Thanks for the rundown, John. Lou |
| Author: | 62 alum [ Thu May 10, 2018 10:49 am ] |
Thanks for your posts and pictures. Had to try it in the water jacket on the 68 head. Mixed up 1qt molasses to a gallon of water. Surprised the jacket did not hold the whole gallon. |
| Author: | and739 [ Thu Feb 21, 2019 10:35 am ] |
After reading this back when the thread was current, I knew I had to give it a try. Not having any immediate car-related rust removal needs I decided to try it on a discarded trencher tooth I picked up at work. Attachment: tooth1.jpg [ 63.06 KiB | Viewed 4557 times ] I used molasses we had on hand in the kitchen (not the Ag grade molasses) and mixed it in an empty Powerade bottle since I was working with a small part. Two weeks later it looked like this: Attachment: tooth2.jpg [ 51.79 KiB | Viewed 4557 times ] Opening the lid, there was a noticeable pressure built up inside. I guess due to whatever reaction was taking place. A quick rinse and towel dry and the piece looks fantastic. Attachment: tooth3.jpg [ 33.43 KiB | Viewed 4557 times ] |
| Author: | coconuteater64 [ Thu Feb 21, 2019 1:12 pm ] |
Yep! That old farmer's trick works well unless there's a good amount of grease. It seems to avoid the areas under the grease. I did a slant exhaust manifold using molasses and it went from junkyard rusty to, well, better. Didn't look factory fresh, unlike my skillet, but good enough to use without having to sandblast. |
| Author: | and739 [ Fri Feb 22, 2019 4:55 pm ] |
Once again you inspired me, coconuteater64. I do have something to de-rust. As soon as i finish the modified exhaust manifold I’m gonna soak it. Now I just gotta find a right-sized container. This piece is too big for a standard five gallon bucket. |
| Author: | coconuteater64 [ Sun Feb 24, 2019 5:03 pm ] |
Quote: Once again you inspired me, coconuteater64. I do have something to de-rust. As soon as i finish the modified exhaust manifold I’m gonna soak it. Now I just gotta find a right-sized container. This piece is too big for a standard five gallon bucket.
I used a dollar store kitchen trash can.
| Page 2 of 2 | All times are UTC-08:00 |
