| Drilling + tapping https://slantsix.org/forum/viewtopic.php?t=6307 |
Page 2 of 2 |
| Author: | Jopapa [ Mon Jul 21, 2003 1:24 am ] |
Quote: Straight pipe thread? What does that look like? I thought all pipe thread had a taper, thats what makes pipe thread pipe thread in the first place (try that 10 times fast!).
I got three successful attempts and then flubbed |
| Author: | bud L. [ Tue Jul 22, 2003 4:26 pm ] |
| Post subject: | ? |
The first one that comes to mind is carb inlets. They use a shoulder on the fitting and a gskt to seal. I believe brake fittings, while double flare, are still straight thread. Probably the fitting of the water temp bulb/capillary tube is also straight pipe, using the taper pipe (external)thread as an adapter/bushing for the manifold(internal tapered pipe thread). Is that clear? |
| Author: | Jopapa [ Tue Jul 22, 2003 4:36 pm ] |
| Post subject: | Re: ? |
Quote: The first one that comes to mind is carb inlets. They use a shoulder on the fitting and a gskt to seal. I believe brake fittings, while double flare, are still straight thread. Probably the fitting of the water temp bulb/capillary tube is also straight pipe, using the taper pipe (external)thread as an adapter/bushing for the manifold(internal tapered pipe thread). Is that clear?
Clear as mud! |
| Page 2 of 2 | All times are UTC-07:00 |
