| Piston troubles!!! Please help https://slantsix.org/forum/viewtopic.php?t=63592 |
Page 2 of 2 |
| Author: | Doctor Dodge [ Thu May 09, 2019 11:54 am ] |
| Post subject: | Re: Piston troubles!!! Please help |
Be sure to do the compression ratio "math" to be sure you have a reasonable effective compression ratio for the cam you plan to use. The last "long rod" 225 (7 inch rod) set-up I did had a .024 negative deck after a light clean-up cut on the block. With a flat top piston, .040 head gasket and a 60 cc head it had 10.1 static compression and 8.0 effective compression with a cam that has a 65 degree ABDC intake valve closing point. DD |
| Author: | Mopar93 [ Thu May 09, 2019 5:22 pm ] |
Great thank you I just got a call from the race shop with my head and we’re going bigger valves, real nice port and polish job with a 3 angle valve job! She should run good when done this is my first 225 so don’t mind my questions I’m 19 and learning lol |
| Author: | GTS225 [ Fri May 10, 2019 4:22 am ] |
Quote: I’m 19 and learning lol
***********************************************************************************OK, so what did you learn with this little adventure? Roger |
| Author: | Mopar93 [ Fri May 10, 2019 7:41 am ] |
My adventure is far from over I still got a lot of manifold testing and carb testing ahead of me but I learned a lot of different set ups and combos that seem to work pretty well I thank you guys so much for your help you are all very knowledgeable people when it comes to these motors!! |
| Author: | GTS225 [ Fri May 10, 2019 1:40 pm ] |
I'm suggesting that the lesson for you today, is to not have the block bored until you have pistons in hand. Roger |
| Author: | Mopar93 [ Sun May 12, 2019 11:10 am ] |
Yea that too now I’ll never hear the end of it from my father lmao but I’m going to be posting lots of questions on here sorry just bear with me!!! |
| Author: | slantzilla [ Sun May 12, 2019 1:52 pm ] |
Just remember, us old guys know more because we made all the same mistakes when we were young too. |
| Author: | GTS225 [ Sun May 12, 2019 1:54 pm ] |
That's what dads are for. Learn to like it......there's a lot of kids that don't have dads that can, or are there, to teach them. Roger |
| Author: | Mopar93 [ Mon May 13, 2019 11:51 am ] |
Again thank yous so much you guys rock my dad isn’t very knowledgeable about these motors as he was always big block everything lol you guys are awesome |
| Page 2 of 2 | All times are UTC-07:00 |
