Need help with my slant adjusting points and just good info..Never had a slant but this is living to it's name
https://slantsix.org/forum/viewtopic.php?t=63802
Page 2 of 2
Author:  MotorHoggGears [ Wed Jul 10, 2019 10:12 am ]
Post subject:  Re: Need help with my slant adjusting points and just good info..Never had a slant but this is living to it's name
Choke works
Author:  MotorHoggGears [ Wed Jul 10, 2019 10:14 am ]
On the ignition coil where is the condenser wire supposed to be
Author:  Reed [ Wed Jul 10, 2019 11:08 am ]
The little capacitor that is mounted on the coil is not the condenser. It is the noise suppressor for the AM radio. Leave it disconnected for now. I THINK it attaches to the - terminal , but if you connect it to the wrong terminal you can ground the coil and not have spark. Just leave it detached.
Author:  MotorHoggGears [ Thu Jul 11, 2019 8:29 am ]
So today I'm getting the bolt for the harmonic balancer but idk if it the right thread that I found on a forum. It was 3/4-16,2"1/4 long
Author:  MotorHoggGears [ Thu Jul 11, 2019 9:15 am ]
Which size is better 2 or 2 1/2 long cause that all the hardware store has? I want a bolt cause its way easier than bumping it.
Parts store has 3/4-16,2 and 3/4-16,2 1/2
But they have the washer 2" any ideas
Author:  Reed [ Thu Jul 11, 2019 9:59 am ]
Go for the 2 inch. An extra 1/2 inch might not fit and it won't give you any benefit over the 2 inch.
Author:  MotorHoggGears [ Thu Jul 11, 2019 10:04 am ]
So 2in long and what about the washer?
Author:  Reed [ Thu Jul 11, 2019 10:47 am ]
A thick washer should be used to sprea the load of the bolt.
Author:  MotorHoggGears [ Thu Jul 11, 2019 10:52 am ]
A2in washer ok or bigger
Page 2 of 2 All times are UTC-07:00
